compression
Old Jun 20, 2008 | 08:45 PM
gtec8285's Avatar
Default compression
i did a compresion test on my car and it did 110 across
is that too low?
what is a good compression?
Old Jun 20, 2008 | 09:20 PM
slowtegkauai's Avatar
Default Re: compression (gtec8285)
what motor? My LS makes 190Psi.
Old Jun 21, 2008 | 06:52 AM
lmike6453's Avatar
You probably aren't doing it right. It's good to have a friend hold the throttle body wide open while you crank, and make sure ECU and Backup fuses under the engine bay are out while performing the test.
Old Jun 21, 2008 | 06:59 AM
Dark@Powers's Avatar
Default Re: (lmike6453)
You have to be doing it wrong.
On a :B18B1 it should be between 135-199
:B18C 135-270
Here is where I got the info and there is a "How to" compression testing in the following pages:
http://www.team-integra.net/se...=1086
There are some more articles/links on the third page.
Old Jun 23, 2008 | 07:28 PM
big_claw's Avatar
Default Re: (Dark@Powers)
I just did a compression test on my 94 RS with 186000 miles.
Dry / Wet
Cylinder 1: 165 / 190
2: 100 / 140
3: 165 / 190
4: 110 / 150
I'm guessing I have an engine rebuild in my near future. What do you guys think?
Old Jun 23, 2008 | 08:59 PM
lmike6453's Avatar
Yea I would say so looking at those numbers.
Old Jun 24, 2008 | 01:18 AM
gtec8285's Avatar
the way i did it is we just pulled out the spark plug/wires then we put that compression tool in the spark plug hole then i try cranking the motor
76 camaro car
Apr 20, 2017 04:47 AM
Belarus
Apr 2, 2010 03:01 AM
umair
Dec 7, 2009 10:37 AM
stockb18c
Oct 13, 2006 08:52 AM
92siracer
Jun 2, 2004 10:29 PM
