hondata with 1600cc injectors
Direct from Hondata
What are the biggest injectors I can run?
The ECU can be re-calibrated to suit any sized injector (make sure you match injector impedance if you are replacing you injectors). However, injectors take a finite amount of time to open and close, so the bigger injectors tend to be less accurate with their fueling at low durations, such as idle. Much depends on the mechanics of the injector, and how quickly it can open and close. With disk type injectors (such as RC 440cc injectors) you can not tell the difference between stock injectors and injectors which flow twice as much as stock injectors, once the ECU has been reprogrammed for the larger injectors (and there is no difference on the dyno either). With race engines we have run injectors up to 4 times the size of the stock injectors.
96redgsr
Jul 21, 2004 09:46 PM
