Leaking Fluid
i was doing a maintenance the other day replacing my dist cap, rotor, spark plugs and wires. i noticed that there were oil leaks all over the head cover, inside the spark plug tube, on the edges of the dizzy cap, and the power steering pump. what could this be? could it be some sort of seal or gasket that i need to replace?
for those of u who have bought off of acuraoemparts.com or other genuine honda parts dealers, if i bought item 7, would buying one give me a set of 4.. or would i need to purchase 4 of them?
when i put my new valve cover on the valve cover gasket and the spark plugs seals cost me about $40 if i remember correctly. and if they offer you the head kit it's not worth it, it's like $300 and it just comes with a head gasket, IM gasket, and TB gasket which wouldnt do anything for your situation.
Modified by integraty95 at 5:43 PM 6/21/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 »</TD></TR><TR><TD CLASS="quote">The reason why is because you need 4 number 7's and 7 number 23's(7 on a LS at least). What you should buy is part number 1 on the diagram.</TD></TR></TABLE>
cool this was the answer i was looking for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraty95 »</TD></TR><TR><TD CLASS="quote">when i put my new valve cover on the valve cover gasket and the spark plugs seals cost me about $40 if i remember correctly. and if they offer you the head kit it's not worth it, it's like $300 and it just comes with a head gasket, IM gasket, and TB gasket which wouldnt do anything for your situation.
$300? what exactly are u paying for? #1 in the diagram is a kit but it's only like $50
TunesEK
Jan 15, 2009 01:35 PM
