computer shot?
Old Aug 6, 2009 | 04:37 PM
littlered06's Avatar
Default computer shot?
my car every once in a while goes into safe mode then comes out by its self... vtec is radomly popping not popping everytime. this started when my battery died and when my mom helped me jump it i think maybe she arced on the battery and maybe fried my computer? the check engine light pops on after driving for a while and goes off when i shut the car off(is off when i start it then pops on agian). it also regects scanners so i cant get a code and i have checked my fuses so i dont think anything is blown. help please
- brian
Old Aug 6, 2009 | 05:07 PM
fasst's Avatar
Default Re: computer shot?
I am having the exact CEL ECU problems as you... Someone please help us both out!!!
Old Aug 6, 2009 | 06:38 PM
bump
Old Aug 6, 2009 | 06:43 PM
Dogginator's Avatar
Daisy... Daisy...
Is this the stock computer?
Old Aug 6, 2009 | 06:53 PM
yeah. my car has a 96spec type r swap with the stock jdm computer
Old Aug 6, 2009 | 06:57 PM
it ran fine until my battery died and my mom helped me jump it to move it and she arced on the battery and im thinking maybe it fried my computer??
Old Aug 6, 2009 | 06:59 PM
Dogginator's Avatar
Daisy... Daisy...
What car is this in (year)? Could you ever read codes?
Old Aug 6, 2009 | 07:12 PM
yeah i have read codes before. its a 96 ls with a 96spec type r swap and hasport jumper harness
Old Aug 7, 2009 | 12:44 PM
bump
Old Aug 7, 2009 | 04:49 PM
xantavar's Avatar
how good is your electronic skills? if you have access to a voltmeter and wiring diagram, your first task should be checking for proper reference voltages at the ecm pinouts.
There is a good chance jumping the car (improperly) fried the ecm.
Old Aug 7, 2009 | 09:27 PM
samsyabi's Avatar
It is happening just because of the malfunctioning of the ECU.
Old Aug 8, 2009 | 07:28 AM
i have a volt meter but have never tested a ecm.... is there a how to? lol there is a shop close to me that chips computers cheap plus a tune but my friend has a type r so i would just have his tune put on my computer so i my just try that
Old Aug 9, 2009 | 06:32 AM
bump anyone eles have any ideas?
Old Aug 11, 2009 | 08:22 AM
lunchtime bump...wasting money with buying a computer?
Old Aug 11, 2009 | 09:12 AM
follie gatts's Avatar
check and clean your grounds wires in the engine bay--a good place to start is to see if the negative battery terminal has continuity with the other grounds to the tranny case and the chassis near the radiator. check fuses under dash and under hood.
i found a junkyard computer for $70 online. PM me for the site.
Old Aug 11, 2009 | 10:07 AM
Dogginator's Avatar
Daisy... Daisy...
Does the CEL illuminate when you start the car (bulb check)?
How did you run the wires for the VTEC solenoid?
Old Aug 11, 2009 | 02:15 PM
check engine light is off when i start the car after driving a bit it will pop on. shut the car off then turn it back on and its gone until i drive for a while again. and vtec doesnt pop often and when it does it hits at a random rpm like 7100 or somthing retarded
the vtec and everything worked fine until the battery took a ****. and when my mom helped me jump it i herd a arc and didnt think much of it but now the car wont cross over and acts wierd. and it rejects the scanners for the check engine light.
its a 96 ls integra
has a 96 spec type r swap
has a hasport jumper harness for the vtec
and a jdm type r computer
Old Aug 11, 2009 | 02:38 PM
its a 96 ls integra
did you check your grounds for continuity using a multimeter? my car would blow a fuse and throw CEL when the auto tranny tried to shift up while in D4. it was a bad ground to the battery.
Old Aug 11, 2009 | 03:36 PM
i'll go check my grounds in a bit. i dont keep tools at home so i'll swing by work in a few
Old Aug 11, 2009 | 05:05 PM
en00be's Avatar
might be your harness
them harnesses have alot of probs
also...sounds stupid but if its falling out of vtec..simply check your oil
Old Aug 11, 2009 | 07:00 PM
oil was the first thing i checked.
Old Aug 11, 2009 | 08:34 PM
en00be's Avatar
hm id lean more towards your harness then
Old Aug 12, 2009 | 12:48 PM
what could go bad with the harness? burnt wire or something?
Old Aug 12, 2009 | 02:24 PM
checked the ground on the core support and the ground on the tranny. checked the fuses and all of them are good.
Old Aug 12, 2009 | 05:18 PM
bump
