ABS DELETE- now having problems
Old Aug 4, 2009 | 01:59 PM
hardvtec90's Avatar
Default ABS DELETE- now having problems
So I completed the ABS delete. I got a non-abs master cylinder, non abs booster, all rs lines, and a 40/40 prop valve. Everything lines up fine. I bench bled the brake master, but when I hook the lines up to it, it only wants to squirt out one of them.
there are 2 lines that go from the master to the prop. valve. I undid both of them from the prop. valve while they were still attached to the brake master. When I had my friend step on the brake, only one of the lines were shooting out fluid. When I bench bled it, they were both shooting out fluid? I am at a total loss. I talked to my friend who only works on hondas and he thinks that there is something with the piston in the brake master thats not giving the other hole enough pressure. Since my car came with ABS he thinks the brake linkage and the brake master piston just dont want to coperate. Could someone please give me some knowlegdable advice?
ricechris0923
Dec 9, 2013 03:27 PM
integrax97
May 3, 2007 12:15 PM
KBG Indey
Nov 20, 2006 12:50 PM
dahoopdahup
May 2, 2006 03:29 PM
zCivic
May 4, 2004 05:49 PM
