LS/Vtec question!?!
Old Aug 10, 2009 | 03:26 AM
92_Integra_GSR's Avatar
Icon2 LS/Vtec question!?!
I'm looking at buying a pre-built LS/Vtec thats going for around $750. I am doing this because currently I have a B17 that is going down hill (blown piston rings, leaking vtec solenoid gasket....) So basically, I was just wondering, for swapping in the LS/Vtec, what must be done to have it in and working correctly?? For example, like engine mounts? and any other stuff? Any help would be great, thanks.
Old Aug 10, 2009 | 07:58 AM
671M2S_DB8's Avatar
Default Re: LS/Vtec question!?!
why would you wana swap in the lsvtec motor while you can just rebuild the b17..if you want slight bump of a displacement just grab a b18a/b internals and install it with arp rod bolts and should be great motor....if you really want to swap in the lsvtec you can use ur own mounts everything mostly can be tranfered from ur b17 to the lsvetec motor
Old Aug 10, 2009 | 08:14 AM
Noob Saibot's Avatar
Well rebuilding the motor is probably more work for him as opposed to swapping one.
keaven07
27
Oct 23, 2012 09:23 PM
bOOsT-FeIn
Feb 26, 2007 06:42 PM
1SickHb
Feb 8, 2005 02:58 PM
made in JAPAN
Jun 11, 2004 11:46 AM
lsvtecrx
Sep 5, 2002 01:10 AM
