easiest way to remove rear mount
Replace the rear motor mount on a 96 integra? looks like a pretty tight squeeze all the way around, looking for any help i can get.
Re: easiest way to remove rear mount
i took off my manifold to get to mine. its simple, just take out the 17's and 19's and then the 14's that mount it down and your good.
Theres should be only 3 bolts on the tranny that connects the mount, and 1 at the motor mount bracket, just take them off and slide it to the left , and it should come out fine.
i had to do the same thing. i took the motor mount that is connected to it with 17 and 18. once i got that off it was easy and lot of rooom to take it off.
If it's a GS-R with stock intake manifold, the rear mount T-bracket is a royal PITA, and so is the intake manifold. When I pulled my engine out, I just unbolted the bracket and let it fall out when I hoisted the engine up. After putting the engine back in, though, I spent at least 2 hours trying to get the bracket back in, and ended up crushing my heater core pipes in the process.
As for the mount itself, I think it would be extremely difficult to remove it w/ the engine and IM still in the car. I replaced mine with the IM removed, and that was even more of a PITA than it was to remove the whole engine.
i put one in my exs gsr, and even after i pulled the im it was still a pian, and i did the same thing patrickgsr94 did, cruched the heater coe pipes.
next time id rather just yank the damn motor.
AdamsAutoAdvice
01-20-2020 07:19 AM
SiR Kid
05-12-2003 05:02 PM
Civichatch972
12-08-2002 11:42 AM
