Oil Pressure Sensor Explained
Old Aug 4, 2009 | 03:47 PM
LOVEthatDC2's Avatar
Default Oil Pressure Sensor Explained
I have another thread up with an 'identify this' part ...
https://honda-tech.com/forums/acura-integra-6/what-goes-here-thanks-2619254/
wondering what the oil pressure sensor actually does? Is it a single pin out or dual?
thanks!
Old Aug 4, 2009 | 05:46 PM
Default Re: Oil Pressure Sensor Explained
nobody?
Old Aug 4, 2009 | 06:09 PM
Circusraven's Avatar
"Inside the switch there are 2 contacts that are spring loaded. They make contact (closed circuit) when there is not enough oil pressure and break the contact (open circuit) when there is pressure. " Got this off the net.
So it seems when oil fills the switch, it spreads the two contacts apart, breaking the circuit, letting the car know there is oil pressure.
Old Aug 4, 2009 | 08:35 PM
hmm thanks
Old Aug 4, 2009 | 09:43 PM
also, is the sensor the same on the b18b block? obd1
Old Aug 14, 2009 | 11:16 PM
93CharcoalHatch
Dec 14, 2005 09:19 AM
thinknology
Jun 9, 2004 02:54 PM
Cowboy
Jun 6, 2003 05:14 PM
Canuk_SiR
Aug 1, 2002 12:16 PM
