intermitted code 16
Old Aug 3, 2009 | 06:53 PM
trueblood's Avatar
Default intermitted code 16
OK so heres the deal. I bought a 92 integra with a built head. I got it with no key, motor not bolted up and never been started.
what was written on computer
b18a1 head
crower 62404s
titanium retainers, dual valve springs
skunk 2 intake (cant verify but not stock)
edelbrock 65mm trottle body
adj. cam gears
venom injectors
clean as a whistle inside..
b18b1 block w/ gsr heads (havent verified)
s1 tranny (know nothing about)
Code 16 pops up (check engine light) I turn car off and wiggle 2 and 3 injector clips ever so slightly. code goes away for a day or so. all injectors have 13 ohm resistance. Today it did it again and this time I turned it off and gave it a few seconds and started it again w/ no code. so its not the injectors or clips? maybe? I have noticed this happens either at hard shifts or after 30-40 mins easy driving. I have read that these computers dont have many problems but thats what I am leaning towards. What do the experts think.
Another seperate issue is i cant advance ignition timing past 16 deg. maxed out on turning room on the dizzy.
dont flame me but I have advanced cam intake and exhaust 1 deg. Been playing with this. Noob to handa but semi good mecanic skills with full shop access.
any help would be appreciated.
Old Aug 4, 2009 | 11:37 AM
trueblood's Avatar
Default Re: intermitted code 16
wow. thought someone out there would have run accross this before.
It did it on the way home today. cut it off for a sec. start it back u and its fine for a coule of miles. It doesnt act up until the engine is hot.
again any help would be appreciated
Old Aug 4, 2009 | 11:47 AM
ek-g6's Avatar
Could be a bad connection when hot, why not replace the injectors clips, maybe its just not making good connection.
Old Aug 4, 2009 | 02:22 PM
redflaredcrx90's Avatar
make sure you useing the right injectors
Old Aug 4, 2009 | 05:20 PM
trueblood's Avatar
inside the #2 and #3 injector clips the metal prongs were slightly bent but fixed that.. I do have some clips on the way and will try that.
How can I know if the injectors are right? He wrote Venom 260cc on the ECU but again cant verify. I will search some info on these injectors.
I will try to find some to test with.
This only happens when its hot.
I do have thoughts of turbo so bigger injectors might be in the future. shoot for 350hp.
Once I get the bugs worked out I'll pull her in the paint booth and slap some electric pearl blue on it.
I have few posts but have logged hundreds of hours of reading. Lots of info on here.
Anyone have a similar setup?
Thanks for the help
Old Aug 4, 2009 | 08:16 PM
ek-g6's Avatar
The injectors should say how much cc they are.
Metal Head
Sep 1, 2008 08:12 AM
square_1
Apr 3, 2007 01:46 PM
SkIp_Civic_Ek6
Jan 17, 2007 07:37 PM
brbHPR
Jun 15, 2003 05:25 PM
