ADVANCING TIMING
Old Apr 1, 2002 | 05:13 AM
maggsgsr's Avatar
Default ADVANCING TIMING
Hi guys,I advanced my timing this weekend to 18btdc,I was wondering what the pros and cons are of this,the car seems to be running a little stronger but I'm wondering if I'm risking blowing the motor?I did a search but it appears alot of previous threads are missing due to the new server.
Old Apr 1, 2002 | 05:36 AM
garados's Avatar
Default Re: ADVANCING TIMING (maggsgsr)
There shouldn't be a risk. Honda says that the timing should be 16 +- 2 degrees. It helps to advance the timing at higher altitudes due to the thinner air.
How did you advance your timing, did you mess with the computer at all, or did you just twist the distributor cap?
Old Apr 1, 2002 | 05:59 AM
maggsgsr's Avatar
Default Re: ADVANCING TIMING (garados)
timing light,and ecu jumper,twisting distrib
Old Apr 1, 2002 | 06:02 AM
garados's Avatar
So you put that thingy on the wires coming out of the passenger kick panel first, hooked up your timing light, then proceeded to twist the distributor, right?
Old Apr 1, 2002 | 06:27 AM
maggsgsr's Avatar
Yea,it took about 5 minutes
Old Apr 1, 2002 | 09:41 AM
juniordc2's Avatar
i helps out engines that are performing in thin air? I live at a pretty high altitude, so if I advance my timing to 18btdc it'll probably equal that of a b18c1 running 16btdc? Civic SIR (SI in states) can run low to mid 15's stock or with little mods in vancouver cause of the sea level altitude, but they run high 15's to mid 16's here stock.
Old Apr 1, 2002 | 09:46 AM
SIK IN DA HED's Avatar
New User
Default Re: ADVANCING TIMING (dc2gsr94)
i wouldnt risk advancing it too much. might create some detonation problems in the future.
bopbop93030
Feb 24, 2009 02:57 PM
allnaturalb16
21
Aug 14, 2007 08:57 PM
kixcrx
Nov 10, 2006 10:33 AM
johnbrooke86
Aug 23, 2004 04:49 PM
98slvrcx
Jul 28, 2002 09:58 PM
