Code 17(VSS) and VTEC question
Old Mar 30, 2002 | 01:42 PM
HaUTSaauce's Avatar
New User
Default Code 17(VSS) and VTEC question
I just threw code 17 i think thats for the VSS. What do i need to check and how do i fix this? Also the same time i started getting this code my VTEC quit working! I checked the oil levels and they are fine and i am not getting a code for the VTEC so i dont know what to check ontop of that
Old Mar 30, 2002 | 03:07 PM
Charles B.'s Avatar
Default Re: Code 17(VSS) and VTEC question (HaUTSaauce)
Check you VSS sensor on top of your tranny to see if there is anything wrong with the sensor. The VSS sensor measures your car's speed. There probably is a problem with it because you are not hitting VTEC. Are you getting a reading on your speedometer? VTEC will not engage untill you reach a certain speed (not only a certain RPM). HTH.
[Modified by SuperDuperEG, 12:09 AM 3/31/2002]
Old Mar 30, 2002 | 07:12 PM
HaUTSaauce's Avatar
New User
Default Re: Code 17(VSS) and VTEC question (SuperDuperEG)
dont see nething physicaly wrong with the sensor. what else should i check ? r there ne fuses that are connected to this that might have shorted?
1clean_ Ej
Feb 28, 2007 08:07 PM
E36 Guy
Dec 11, 2003 03:15 PM
E36 Guy
Dec 9, 2003 10:21 PM
DumpedSi
Sep 8, 2003 04:18 PM
jonas
Mar 15, 2003 03:09 PM
