advance timing?
Old Mar 29, 2002 | 11:42 AM
knighteg's Avatar
Default advance timing?
hey everyone, i am wondering if there is a way to get to my flywheel to more accurately advance my timing. i have a 94 gsr, with a 95 b18c1 engine. my friend has a 93 prelude and he can advance his timing and has a rectangular opening to his flywheel which helps him see how many degrees he can advance his timing, but when he tried to do this with my car, there was no rectangular opening to my flywheel. so my question is of those of u with 94-95 gsr(obdI) tegs, where is the opening to the flywheel?
Old Mar 29, 2002 | 02:37 PM
red97gsr's Avatar
Default Re: advance timing? (knighteg)
I don't know how much more accurate your way is going to be compared to the 'normal' way. I've never even heard of anyone that measured timing from the flywheel. But even if it possible, I guarantee that you won't feel it anyway. The most gain I've ever seen on a dynosheet due to advancing timing was ~3whp (which you can't feel anyway and could be within error tolerances too). So if your talking about being more accurate by about, let's just say ~.5deg, than that it may/may not equate to maybe .5wp either way. Just advance the timing the normal way.
Old Mar 29, 2002 | 03:16 PM
kkim's Avatar
is your friends car an auto? I believe the autos have that rubber plug on the trans, manuals don't.
Old Mar 30, 2002 | 11:24 AM
ndustryalGSR's Avatar
Default Re: advance timing? (kkim)
My brother's manual transmission'ed '96 Prelude Si has that opening on the transmission. It has no identifying marks on the crank pulley, so you have to set the timing using the flywheel.
Since Integras have crank pulley marks to set the timing (and no opening in the tranny to check the flywheel), I'd suggest setting the timing the "regular" way -- with the crank pulley and a timing light.
Good luck.
Old Apr 4, 2002 | 03:33 PM
knighteg's Avatar
Default Re: advance timing? (ndustryalGSR)
and wht is the "regular" way, my friend thought his way was the "regular" way,
can someone please, explain in more detail of the "regular"way to advance my timing, thx
Old Apr 4, 2002 | 10:21 PM
SIK IN DA HED's Avatar
New User
advance timing with your flywheel? whut the? you advance timing by moving your distributor. hHAHAHAHAhahahahAHAHAHA
Old Apr 5, 2002 | 12:44 PM
kkim's Avatar
try this...
http://www.hondaracing.ca/installs/timing/index.htm
Old Apr 5, 2002 | 12:48 PM
knighteg's Avatar
thx kkim
Old Apr 5, 2002 | 01:01 PM
Jesse H's Avatar
Default Re: advance timing? (dlplayboy)
no stupid.
on certain hondas, and perhaps other cars, the timing marks are on the flywheel instead of the crank pulley.
Old Apr 5, 2002 | 05:21 PM
New User
Default Re: advance timing? (Jesse H)
no stupid.
daym, some guys on this forum have their panties on too tight. got a funny bone in your body? well... find it and shove it up your candy ***.
prelude2.2vtec
Mar 3, 2009 04:31 AM
anomale
Nov 30, 2008 01:34 PM
deucedeuceEK
Jan 2, 2007 08:52 AM
H23ludedude
Feb 20, 2003 05:23 AM
BoostedH23a1
Aug 20, 2002 05:31 PM
