difference between the years...
Old Mar 29, 2002 | 08:22 PM
Phil DeVtec's Avatar
Default difference between the years...
can someone explain what the exact difference between the 94-01 tegs...what year do you guys prefer? thanks...
Old Mar 29, 2002 | 08:39 PM
garados's Avatar
Default Re: difference between the years... (go_speed_racer)
94 & 95 are obd1 and 96-2001 are obd2. 94-97 have the same body, i think, 98-2001 have a different body. The wheels between most of the years are different. The suspension and engine have basically been unchanged. Most of the changes are in the body and electronics. IMO 97 was the best year, I think, because the ITR came out, but I like 95 because that is the year of my car
[Modified by garados, 5:41 AM 3/30/2002]
Old Mar 29, 2002 | 08:47 PM
Default Re: difference between the years... (garados)
thanks a lot dyune...i need this info cuz right now im looking to buy a 95 gsr...and i just wanted to make sure that it was going to be a good buy...its really either that or going EK civic with swap...but i like the "luxuries" that the gsr has...thanks again
by the way...what difference in the body is there???
Old Mar 29, 2002 | 08:52 PM
garados's Avatar
The front headlights are differently shaped they are slanted instead of straight up and down, the tail lights of the 98+ are completely red, no amber. The front bumper has a lip that sorta sticks out a little bit more than the 94-97. The sideskirts could be different, but probably nothing noticable. The most different change between the 98+ and the 97- is the front end, the lights and the bumper cover.
[Modified by garados, 5:53 AM 3/30/2002]
Old Mar 29, 2002 | 08:57 PM
thanks for all your help man...
Old Mar 29, 2002 | 08:58 PM
garados's Avatar
no problem. Good luck with the car.
Old Mar 29, 2002 | 09:17 PM
dc24me's Avatar
At one point in time, the ACURA logo was changed to the on the wheels and steering wheels, side impact protection bar in the doors and mid section of the car under the rest seat, mirrors changed slightly, later models had a hatch release lever outside of the car. 94-95s with the OBD1 are supposed to be faster and more responsive to mods. Lighter too.
Old Mar 29, 2002 | 11:35 PM
IN VTEC's Avatar
A '99 GS-R would my favorite if I had to pick any year.
Talking about GS-R's here, with some applicability to other trim levels:
'94 option of factory foglight kit
Paradise Blue Green, Milano Red, Granada Black Pearl, Frost White
'95 gets optional leather seating
'96 gets OBD-II and vacuum lines are routed differently on the IM
Dark Green color?, Milano Red, Granada Black Pearl, Frost White
'97 gets new mirror housings, intermittent wiper settings, symbols on center caps and strg wheel air bag, in-dash CD player, change in air intake tube design - placement of resonator, different gauge cluster meter and climate control appearances
'98 gets new front/rear bumpers, headlights, lighter ITR ABS pump intro'd in '97 ITR, trunk latch moved to hatch lid from inside, all-red tail light lenses, different amber front bumper lenses, Raybrig factory foglight option, OEM bodykit option, different GS-R exhaust tip (weld-on instead of screw-on chrome tip), leather standard, and different fuse design (PITA to take out)
Super Sonic Blue Pearl, Nighthawk Black Pearl, Adriatic Blue Pearl (LS/GS only)
'00 gets exhaust/catalytic converter alterations
Ahhh! Forget the color options...it's friggin' 3:30AM.
Old Mar 29, 2002 | 11:43 PM
Calavera's Avatar
Default Re: difference between the years... (IN VTEC)
uhm....'94-97 front seats only have one lever that's used to adjust the back support while the '98-01 front seats have two *****--one adjusting the back support, the other adjusting height.
'00~'01 Integras also come with immobilizers built into the car.
[Modified by Calavera, 12:44 AM 3/30/2002]
Old Mar 30, 2002 | 06:44 AM
Default Re: difference between the years... (Calavera)
thanks for everything guys...all the info really helped me decide to go ahead and go for the 95 gsr...do you think a 95 gsr with 58,000 miles for 10,500 is good?? i really appreciate all the info!
Old Mar 30, 2002 | 08:49 AM
B18 B e a s T's Avatar
Default Re: difference between the years... (GoSpeedRacer)
Yes that is a good deal. Especially since it's a 95 with such low mileage.
NWP4LIFE
Sep 8, 2008 09:02 AM
thaigsrdrv16
Mar 4, 2002 03:25 PM
95-AcuraIntegra-GSR
Feb 19, 2002 01:12 AM
