help!
Old Mar 30, 2002 | 11:59 AM
swarsing's Avatar
Default help!
just tried tuning up (cap,rotor,plugs,wires all oe from the dealer)100%sure everything is on properly and my car won't start even tried putting the old stuff back on ,my car is a 93 si w/95 b18c1
Old Mar 30, 2002 | 12:03 PM
mickey513's Avatar
Default Re: help! (swarsing)
Did you put the spark plug wires in the wrong order onto the dis. cap? Because if it's not correctly plug into the corresponding hole on the dis. cap, the car will not start. If that is correct, then double check to make sure the plugs, and dis. rotor inside is tight. Should be either of these two.....
avargas28
Apr 15, 2009 05:32 PM
smoovekriminal
Aug 17, 2007 09:55 PM
QUAIJAI
Jan 27, 2005 04:12 PM
reese
Sep 2, 2002 11:59 PM
