can someone explain engine timing??????
Old Mar 30, 2002 | 02:58 PM
paulyman's Avatar
Default can someone explain engine timing??????
i have an integra 2000 ls
should i advance the timing on it
what are the pros and cons.
will it hurt anything
i have a i/e/h and high flow cat.
Old Mar 30, 2002 | 03:20 PM
vteg's Avatar
New User
Default Re: can someone explain engine timing?????? (paulyman)
Advancing timing may give you a slight increase in torque, but you may also get detonation, and on an ls, you may have to use better gas(89 or 91/92). My personal suggestion, if you decide to do it, buy a timing gun, or borrow one. This has been discussed a lot. You may be able to search and find more info on the board. I found this cool article on the subject though http://www.egr.msu.edu/autoweb/Class...ns/ignsys1.pdf
Advanced timing was the first thing I did to my teg. I eventually returned it to stock, since I was getting some pinging at low revs during take offs.
Old Mar 30, 2002 | 03:28 PM
B18 B e a s T's Avatar
Advance timing is when the spark occurs ahead of time, and retarding is when the spark occurs after.
Timmay
17
Jun 20, 2007 09:55 AM
kixcrx
Nov 10, 2006 10:33 AM
MKIIISupra
Aug 7, 2005 04:38 PM
