Bars question
Old May 29, 2002 | 09:49 AM
01gizzer's Avatar
Default Bars question
I am in the market for all sorts of bars for my car like sway bars, tie bars etc. I was wondering if any company in the suspension business really stands out and their products make a big difference over another brand.
Old May 29, 2002 | 10:08 AM
01gizzer's Avatar
Default Re: Bars question (01gizzer)
Im thinking about the Spoon tie bars and strut bars and suspension technique sway bars.
Old May 29, 2002 | 10:16 AM
garados's Avatar
I like the suspension techniqies sway bars. They say to install both before you go driving, but I didn't listen. I put the rear sway bar on, and the car didn't lean even half as much as before. When I replaced the front with the ST sway bar, there was even less body roll. As for tie bars, I can't help you.
Old May 29, 2002 | 10:58 AM
bamaTeg's Avatar
New User
Default Re: Bars question (garados)
I've got the rear ST bar on my 95 LS as well and love it. Actually the guy at ST recommended I didn't buy the front bar because it would counteract the gain in oversteer I would get from the rear bar so I never did. Did you get more understeer by putting the front ST bar on ? thanks!
Old May 29, 2002 | 11:00 AM
bamaTeg's Avatar
New User
Default Re: Bars question (bamaTeg)
another question I have is that unless ST has changed something then the front bar is an add on bar that hangs low. You said you replaced the front bar. How did you do that?
Old May 29, 2002 | 01:02 PM
t's Avatar
t
Do some research into the bars (especially the sway bars), as it can change the handling of the car.
Old May 29, 2002 | 01:17 PM
HondaJon's Avatar
Default Re: Bars question (t)
ITR rear sway bar + BSQ mounting kit
Spoon front and rear upper strut bars
Benen rear lower tie bar
That should be more than enough "BARS" for you
Old May 29, 2002 | 01:27 PM
frogsr's Avatar
Default Re: Bars question (HondaJon)
a good solid setup right here. the spoon rear tie bar is a nice piece, too. many people complain about the hinges, but that's what the nuts are for. tighten them down after proper adjustments, and you're good to go.
austinkli
Suspension & Brakes
Mar 22, 2010 07:00 PM
fluke83
Jul 6, 2004 03:13 AM
B_CRUZ!
22
Jun 26, 2002 03:25 PM
Jordan_4WS
Feb 22, 2002 12:41 AM
vpforeva
Oct 8, 2001 03:00 AM
