check engine light
well actually i go to school in San Antonio but i live in Corpus Christi.....thats 2-2.5 hrs from SA. i went to autozone and they checked the code and it turned up throwing a P0420. it is something about exhaust being below threshhold. somethin like that. anyone ever have this happen? what did you do?
You have to jump your service connector. Then turn your ignition on but leave the engine off. Your ABS light will flash codes at you. Slow Flash = 10 and fast flash = 1. So Flaaaaash, Flaaaaash, flash, flash, flash = code 23 Knock Sensor.
There you go.
Service connector is under the glove box in a green holder. you will see it. use a piece of wire or something to create the circuit.
This is for a 94+ integra
ECU CODES
1 Oxygen Content
3 Map Sensor
4 Crank Angle Sensor
5 Map Sensor
6 Coolant Temperature
7 Throttle Angle
8 TDC Position
9 No 1 Cylinder Position
10 Intake Air Temperature
11 Intake Air Temperature
12 Exhaust Gas Recirculation System
13 Atmosphere Pressure
14 Electronic Air Control
15 Ignition Output Signal
16 Fuel Injector
17 Vehicle Speed Sensor
20 Electronic Load Detector
21 VTEC Solenoid Valve (1.8L GSR)
22 VTEC Oil Pressure Switch (1.8L GSR)
23 Knock Sensor
30 TCM Signal A
31 TCM Signal B
41 O-2 Sensor Heater
43 Fuel Supply System
45 System Too Rich or Too Lean
48 Primary Heated O-2 Sensor
54 Crankshaft Speed Fluctuation Sensor
61 Primary O-2 Sensor Circuit
63 Secondary O-2 Sensor Circuit
67 Catalyst System
70 Automatic Transaxle
71-74 Random Misfire
80 Exhaust Gas Recirculation
86 Engine Coolant Temperature Circuit
90 Evaporative Emission Control System Leak Detected
91 Fuel Tank Pressure Circuit
92 Evaporative Emission Control System Insufficient
[Modified by Fooser, 10:44 PM 6/3/2002]
There you go.
ECU CODES
1 Oxygen Content
3 Map Sensor
5 Map Sensor
7 Throttle Angle
8 TDC Position
16 Fuel Injector
23 Knock Sensor
30 TCM Signal A
31 TCM Signal B
67 Catalyst System
can ya ive me a better more detailed description on how to do that?
[Modified by Fooser, 2:52 PM 6/4/2002]
Go buy a Chilton repair manual for your car becuse i had to do the same thing and found out that one of my pistons were cracked...from a misfireing code 71-74
[Modified by TurboB18C1, 6:19 PM 6/4/2002]
Jer'rome
Honda Civic (2001 - 2005)
Nov 2, 2007 02:19 PM
ph0shizzle
May 13, 2006 08:36 PM
lilxvtecxpwr
Oct 13, 2002 11:04 PM
