tune up ?
Old Jun 1, 2002 | 01:02 AM
homegrown96734's Avatar
Default tune up ?
i have 54,000 mi..my car sounds like it pings on idle on a quiet night...should i get a tune up now or wait till 60,000 . or should i just put fuel injector cleaner...need opinions...thanks
Old Jun 1, 2002 | 01:26 PM
Weston's Avatar
Default Re: tune up ? (homegrown96734)
Might just be the valves. A valve adjustment made mine run a lot quieter and smoother. New plugs + distributor cap & rotor are also a good idea; I got a 3-4 mpg increase just by changing the cap. http://www.thepartsbin.com has pretty good prices for the cap/rotor. Don't pay the dealership to do something that simple, it's very easy to do yourself. Just don't strip the rotor screw like I did
Old Jun 1, 2002 | 02:05 PM
EVOTHIS's Avatar
Default Re: tune up ? (Weston)
you are comming up on your 60,000 mile service which inlcudes:
Oil change
replace air filter
lube chassis
rotate and balance all four wheels and tires
4 wheel alignment
replace spark plugs
valve adjustment.
and of course inspect everything.
Old Jun 1, 2002 | 02:22 PM
ragejed's Avatar
Default Re: tune up ? (b18c ya)
Im on 43k. When is my next service.....And what does it intail?
Old Jun 1, 2002 | 02:37 PM
EVOTHIS's Avatar
Default Re: tune up ? (ragejed)
45k service
oil change
clean air filter (not replacement)
replace coolant
replace brake fluid
Inspect everyting.
rotate and balance tires.
Old Jun 1, 2002 | 02:40 PM
EVOTHIS's Avatar
don't pay for a new rotor, plugs, wires etc...
acura had a recall on most 96-98 Acuras for emisions reasons. After you get over 75K the dealer will replace these for you and give you an oil change. check with your dealer to see if your car applies.
Old Jul 15, 2002 | 08:33 AM
ragejed's Avatar
what was wrong with the emissions?? my 98gsr has 42k on it.... would it perform bad? or could i just replace it my self?
Kokxxy
Aug 22, 2015 04:01 PM
BigZ88
Dec 3, 2003 05:50 AM
Nocturnal
Aug 17, 2003 09:54 AM
vtecdc2
Jul 15, 2002 06:41 AM
CW-ITR-329
Jan 22, 2002 08:57 AM
