B20 VTEC !
Old May 30, 2002 | 10:59 AM
95 GSR B20VTEC's Avatar
Default B20 VTEC !
Hey everyone I just recently bought a car off a friend of mine, Its a 95 GSR 4door, Its got a B20B Block, B16 Head, B16 Transmission, P28 Chipped ECU, Type R Cams, JG Cam Sprockets & Heads Milled .35. It runs great and its really quick.. Ive got $400 At the moment to spend, What would you all recommend I get for the most bang for the buck performance wise, fill me in !
Old May 30, 2002 | 11:11 AM
b18b98's Avatar
Default Re: B20 VTEC ! (95 GSR B20VTEC)
Is the bottom end built to handle high revving? If it isn't save your money to build it up. If it is, then a little 50 shot wouldn't hurt.
Old May 30, 2002 | 11:12 AM
BoM's Avatar
BoM
start saving for some rods and pistons
cause that b16 trannys going to wear your block out.
Old May 30, 2002 | 11:13 AM
Default Re: High Revving
Well, Im pretty sure he designed it for high revving he told me that he normally shifts at around 8000 maybe a tad over.
Old May 30, 2002 | 11:16 AM
Default Re: B20 VTEC ! (BoM)
Oh really? What do some good pistons & rods go for nowadays
Old May 30, 2002 | 12:07 PM
oldschoolflava's Avatar
Get some probe pistons and keep the stock rods or get some from probe
Old May 30, 2002 | 12:13 PM
Bozotk's Avatar
New User
Default Re: B20 VTEC ! (oldschoolflava)
i would save up more, and start looking into a turbo.... maybe some turbo cams or some sleaves/pistons or something
[Modified by Bozotk, 1:13 PM 5/30/2002]
Old May 30, 2002 | 01:09 PM
startroops's Avatar
Default Re: High Revving (95 GSR B20VTEC)
Ouch, that motor is taking some beating man!! But make sure you ask him if the bottom end has been built before? And if you have that kinda money, try some Toda/CTR cams, maybe an ITR IM... There are many ways to spend that 400 of yours... How about dyno tuning?
Make sure you spend youe money well Enjoy the new car.
Old May 30, 2002 | 01:10 PM
startroops's Avatar
Default Re: High Revving (startroops)
And I just read the post again, if you are planning to get pistons, make sure they fit since your head is milled, HTH.
Old May 30, 2002 | 01:20 PM
threatcon13's Avatar
New User
Default Re: B20 VTEC ! (Bozotk)
do you even know what youre talkin about? btw stock cams are fine to run w/ turbo. im pretty sure the bottom end was built up, it would be pretty ridiculous to run stock pistons on a b20/vtec head swap. skunk2 manifold or 2.5 inch exhaust would be a logical next step.
Old May 30, 2002 | 02:32 PM
JCushing's Avatar
find out exactly what has been done to strengthen the bottom end every little detail. dont worry what he used to rev it to hehe...... then get back to us. if the bottom end is built then look into maybe suspension/brakes if they need work.
thatguamanionkid
Mar 8, 2009 10:52 AM
pat91hb
Oct 10, 2008 12:09 PM
JlDlM Ek
May 2, 2004 07:49 AM
Dan GSR
Sep 19, 2003 08:07 AM
Jayphil
May 27, 2003 09:40 PM
