how to lube integra windows?
Old Jun 1, 2002 | 01:02 PM
comptechgsr's Avatar
Default how to lube integra windows?
yeah, they roll down slower now n ish........
wut/how do i do it
Old Jun 1, 2002 | 01:52 PM
GSRaCeRbOI's Avatar
Default Re: how to lube integra windows? (comptechgsr)
first clean the windows w/ some glass cleaner (both inside and out) or you might as well wash your car too if you have time.. after the windows are cleaned.. roll it down... I used armor all on the black plastic weather stripping.. I know some people use silicone spray lubricant.. but I didnt have any and the armor all has worked good for me... I noticed even though my dash and panels were kinda dusty.. it was still smooth w/ the armor all.. so i tried it on my window weather stripping and it worked..
if that doesnt help you might want to take off your door panel.. and see if the window is sliding well along the track/guide rails..
Old Jun 1, 2002 | 10:25 PM
Sp0oNCiViCTyPeR's Avatar
Default Re: how to lube integra windows? (GSRaCeRbOI)
how do i remove my door panels? i have a '94 Integra LS
Old Jun 2, 2002 | 07:30 AM
primoEF's Avatar
Default Re: how to lube integra windows? (Sp0oNCiViCTyPeR)
just spray some WD40 on the rail (the one thats standing straight)
Old Jun 2, 2002 | 10:17 AM
GSRaCeRbOI's Avatar
Default Re: how to lube integra windows? (b18k1)
WD40 works for about 1 week.. then it attracts dirt and dust.. and your back to square 1.. slow windows....
Old Jun 2, 2002 | 12:32 PM
Weston's Avatar
First, roll down the window. There's 3 phillips head screws, one in the armrest, one behind a little cover by the door handle, and the other is very easy to see... it's near the top of the panel and towards front of the car, once you get the screw out, you should use a flat head screw driver to pull the plastic piece out (the piece that the screw came out of). Then you can pull at the edges of the panel and they should just pop out. When you have all the clips popped out, you can slide it upwards and it will come off. Reinstallation is pretty much the opposite of the removal order. It's kind of a pain to get it back on though; make sure the top is in all the way.
FijiBlueFG2
Honda Civic (2006 - 2015)
Sep 14, 2009 01:07 PM
Krew3000
Apr 26, 2009 11:50 PM
Lightsped
Aug 28, 2008 11:14 AM
jeremiahsieler
Mar 3, 2004 12:18 PM
SilverDc2
Aug 21, 2003 04:29 PM
