Integra Tech Help
Old May 29, 2002 | 11:07 AM
Warrior8743's Avatar
Default Integra Tech Help
Hey guys.....i need some help with my power antenna in my 1997 integra ls. The antenna is broken and makes a clicking noise when it raises so my question is how do i access the antenna to either remove it completly or just cut a wire to keep it from raising when i start the car. Let me know......thanks
Old May 29, 2002 | 11:10 AM
Johnny Gasparini's Avatar
I didn't ask for a dime.
Default Re: Integra Tech Help (Warrior8743)
You have to remove the trunk liner to gain access.
Old May 29, 2002 | 12:37 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
if you want it to stay up, then pull the trunk liner trim panel back, and then w/ the radio on and antenna up, pull the wiring harness plug out (not the antenna cable, just the harness). If you want it to stay down, do the same thing, but w/ the antenna down, obviously.
Old May 29, 2002 | 12:46 PM
redlinegsr's Avatar
Default Re: Integra Tech Help (PatrickGSR94)
yea it is acessable from behind the trunk lining. mine started making noises to so i replaced it with a zendar which looks much better
paniaguae640
Jul 27, 2009 08:28 AM
hondaboy4life
Jan 2, 2008 06:18 PM
vietintegboi
May 30, 2006 02:10 PM
jonzel
Mar 13, 2006 02:08 PM
Ben-VTEC
Feb 28, 2003 10:55 PM
