Check Engine Light
Old Aug 21, 2002 | 10:05 PM
Cyrio's Avatar
Default Check Engine Light
My check engine light came on so I checked it and it was a code 45, which is either running to lean or too rich. So I reset it and it went away for about 200 miles then came back on tonight. What should I do about this?
Old Aug 21, 2002 | 10:08 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Check Engine Light (Cyrio)
what do you have on your car?
Old Aug 22, 2002 | 06:56 AM
Cyrio's Avatar
Default Re: Check Engine Light (dLo GSR)
greddy turbo and ecu... i bought the car like this.
[Modified by Cyrio, 7:56 AM 8/22/2002]
Old Aug 22, 2002 | 07:23 AM
bullz's Avatar
I think your Fuel Pressure is off and needs to be adjusted....I dunno.
Old Aug 22, 2002 | 07:34 AM
b18b98's Avatar
Default Re: Check Engine Light (iLLestjr)
What is your Fuel Setup?
Old Aug 22, 2002 | 07:57 AM
Cyrio's Avatar
Default Re: Check Engine Light (b18b98)
as far as i'm concerned its stock... I didn't know about the ECU until the check engine light came on and i looked down there to figure out the problem. What do i do if i'm running lean, which i assume i'm doing, to fix the problem? How do I adjust my fuel pressure?
TeamSumner
Sep 29, 2014 05:14 AM
kleen98accord
Oct 10, 2006 10:20 PM
taibui
Mar 23, 2004 02:44 PM
RAB
Mar 9, 2003 10:00 PM
RaVAGE00
Apr 13, 2002 02:34 PM
