lsvtec
Old Aug 22, 2002 | 05:26 PM
wykid13sec Teg's Avatar
Default lsvtec
will a lsvtec build low end gsr head and tranny be stronger than a gsr
Old Aug 22, 2002 | 05:45 PM
Davanca's Avatar
Default Re: lsvtec (wykid13sec Teg)
hell yeah
Old Aug 22, 2002 | 07:36 PM
lazy bum shaughn's Avatar
Can you rephrase that question?
Old Aug 22, 2002 | 11:57 PM
RolioPolio's Avatar
Default Re: lsvtec (Mixxed Bboy)
that question went about 3 different ways
Old Aug 23, 2002 | 01:28 AM
MR. ARIZONA's Avatar
Default Re: lsvtec (RolioPolio)
Old Aug 23, 2002 | 08:49 AM
X2BOARD's Avatar
Default Re: lsvtec (QUICKTEG)
I think he meant, " Will an LSVT with a built bottom end be stronger than a GSR ?"
If the LSVT is built and the GSR is not... definitedly LSVT will be stronger.
Old Aug 23, 2002 | 05:26 PM
will a lsvtec with gsr head and trannt be as strong as a gsr.
and will it take rev like a gsr
Old Aug 23, 2002 | 08:54 PM
Armed Ferret's Avatar
with stock internals?
not unless you wanna get with the mad scientist and pull apart the block to replace the piston rings you'd fry......along with the rods you'd throw.
the ls has a bad r/s ratio for high revs......HOWEVER, building up the bottom end with forged rods/ARP rod bolts definitely helps. High revs are much easier to come by and safer to do; your engine will also last a lot longer.
Old Aug 23, 2002 | 11:42 PM
lsvtec4door's Avatar
Default Re: lsvtec (zoomintegra)
i think we have gone over this a million times if ur gonna do an lsvtec do it right...dont do a half as job so it lasts a week....replace everything...if ur gonna just rig it togather and use all the old and stock parts i wouldnt bring it over 7200.......if u do it right with forgred rods and pistons u could really bring it up to whatever u want..my car makes power all the way up to 9k
Old Aug 24, 2002 | 06:30 AM
broke1's Avatar
Default Re: lsvtec (lsvtec4door)
it could be as strong if not stonger if it's built right.
qpzm12
May 24, 2011 11:54 PM
Superqwak
May 24, 2011 06:28 AM
integdriver4
10
Apr 25, 2007 02:00 AM
truteg801
Oct 27, 2005 05:15 AM
