Turbos???
i am thinking of purchasing a turbo for my 1999 acura integra GSR, i was wondering what types of modifications would i need before hand? and what should i get? turbo wise. thanx
If you keep your car wid stock internals you can put out like 205 whp wid 4-6 psi. but if you wanna build up your engine, then you will need a new ignition, wires, plugs, fuel rails, fuel regulator, pistons, rods
pistons and rods.. i agree. building up your motor will require you to replace the "weak" parts of a stock motor.... which is pretty much the rings, rods, and pistons. you can safely boost 7lbs on a stock motor. more than 7lbs is at your own risk. get the DRAG3 kit... slap it on.. install it the right way... and youre good to go.[Modified by dlplayboy, 11:44 PM 8/20/2002]
Don't abuse your car! If you don't know about turbo's do LOTS OF RESEARCH before you buy a kit. Turbos need tender loving care, and if you don't give it to them, they'll brake your wallet.
