VTEC Engagement Variable
Old Aug 20, 2002 | 03:19 PM
AcuraFiend's Avatar
New User
Default VTEC Engagement Variable
What are the variables that determine whether or not vtec engages? I know oil pressure is a factor but what about throttle position, etc, etc. This came to mind while driving in 4th gear ~25mph(came out of a corner, didnt have a free hand to shift so i just let it go). The thing is that your speed climbs very slowly when in such a high gear but eventually it gets up into the 7 grand range, does vtec engage or just keep on revving on the original cam profile?
Ryan
Old Aug 20, 2002 | 03:36 PM
mugenracer's Avatar
Default Re: VTEC Engagement Variable (AcuraFiend)
Oil temperature
Oil pressure
Speed (19mph)
Engine temperature (tied to oil temp)
Throttle position. (i think its 50% or above)
In fourth gear vtec should come in around the normal point (4400) if you have the accelerator more then half way down
[Modified by mugenracer, 12:37 AM 8/21/2002]
Old Aug 20, 2002 | 04:09 PM
poison's Avatar
Default Re: VTEC Engagement Variable (mugenracer)
Oil temperature
Oil pressure
Speed (19mph)
Very well said
Old Aug 20, 2002 | 07:40 PM
harryg's Avatar
Default Re: VTEC Engagement Variable (poison)
i thought it was
rpm
engine temp
oil pressure
speed
throttle
no big deal really.. close enough
Old Aug 20, 2002 | 07:51 PM
samagon's Avatar
before 50% throttle it switches over at about 5grand.
AznBlueBoy
Nov 29, 2011 12:25 PM
ALL-MOTOR-BUBBLE
Mar 18, 2003 06:44 PM
All Motor EG
Aug 23, 2002 07:57 PM
zer0zer0 TypeR
Jun 6, 2002 04:53 AM
snb3
Dec 14, 2001 12:27 AM
