Broken Rear LCA Bolt HELP!!!
New User
Hey the dreaded rear LCA bolt broke when I was putting on my new suspension. What did you guys do to fix it? I used a sawzall and cut the bolt off and I got the shock out but part of the bolt is still seized inside the bushing!!! I tried using a punch and getting it out but no luck. It's in their tight. What should I do? I know this has happened to many of you. Thanks for any help
New User
Re: Broken Rear LCA Bolt HELP!!! (BoM)
Yeah that crossed my mind. I tried taking that bolt out to remove the whole thing, but it's seized also. I geuss I will have to break that one off too. Lovely
Re: Broken Rear LCA Bolt HELP!!! (_Shadow_)
Is the arm still connected and everything? How'd you manage to get the shock out? So is it possible for you to put in the new suspension? LIke the springs? Will the car still ride with the broken bolt or will that be unsafe.
