clutch help quick!!!!
Old Aug 27, 2002 | 12:20 PM
grnteg98's Avatar
Default clutch help quick!!!!
so i get into the car, start it up, the clutch pedal feels like it's useless. normally, with my foot on the brake pedal, the clutch will engage even to where the brake pedal is... now it is catching like 2 inches off the floor, then flops the rest of way out.... what can this be, i'm assuming either the throw out bearing or possibly the whole clutch, i doubt it's the pressure plate b/c i've heard you really have to beat the hell out of it to break it. anybody know what this is or have had this problem before. thank you
Old Aug 27, 2002 | 12:46 PM
grnteg98's Avatar
Default Re: clutch help quick!!!! (Lord Titus)
for a leak?
Old Aug 27, 2002 | 12:59 PM
grnteg98's Avatar
98 ls
Old Aug 27, 2002 | 03:46 PM
grnteg98's Avatar
from talkin to people who know their stuff, i'm pretty sure it's either the master or slave cylinder, i heard the repair kit is like 6 bucks to buy... it's a hydraulic clutch by the way... hopefully it won't be too much of a bitch to fix.... thanks for your help
Old Aug 27, 2002 | 03:57 PM
GSRwBOOST's Avatar
Default Re: clutch help quick!!!! (tooslow2race)
if you replace it or fix it.. just make sure you bleed the lines and keep that resivour full so you dont pump air into the lines.. talk about a pain in the *** then... LOL
Old Aug 27, 2002 | 05:51 PM
grnteg98's Avatar
Default Re: clutch help quick!!!! (GSRwBOOST)
any ideas how much this is gonna cost me?
Old Aug 27, 2002 | 06:20 PM
uNF$@#!'s Avatar
bleed the car yourself.
take a 8mm wrench and losen the clutch bleed valve and bleed away. be sure to keep filling the clutch fluid reservior.
[Modified by Soup ****, 10:21 PM 8/27/2002]
Old Aug 28, 2002 | 01:52 PM
grnteg98's Avatar
Default Re: clutch help quick!!!! (Soup ****)
so what do i do if i bleed it and it doesn't fix anything???????
Old Aug 28, 2002 | 07:22 PM
grnteg98's Avatar
ttt
Old Aug 28, 2002 | 07:28 PM
Padronis's Avatar
Then you probably need to replace the slave cylinder.
thehatchninja
Feb 16, 2004 02:15 PM
C_Rock77
Aug 16, 2003 05:39 AM
respectblades
Jun 16, 2003 07:28 AM
dbman96
Feb 8, 2002 03:33 PM
vtecdc2
Sep 30, 2001 06:41 PM
