9005 conversion?????
Old Aug 26, 2002 | 04:51 AM
combustion's Avatar
Default 9005 conversion?????
what do you have to do ? do you just switch high beam bulbs into the low beam spots and if so do you replace the high beams with something else??
Old Aug 26, 2002 | 06:44 AM
JK882's Avatar
Default Re: 9005 conversion????? (combustion)
http://www.bmwe34.net/E34main/Upgrade/More_light.htm
Old Aug 26, 2002 | 07:15 AM
WOTTEG's Avatar
There are LOTS of threads that will help with the specifics. But as a high-level overview:
Buy Sylvania Silverstar 9005 bulbs.
Compare their plugs to the plug of the stock low-beam bulbs.
Use a dremmel or X-Acto to remove some material from the 9005 plugs.
Install the 9005 bulbs in the low-beam sockets.
Once you have the two sets of bulvs in yout hands, you can see what you have to remove. I think one of the posts here has a picture too.
Good luck.
deerman2701
Apr 16, 2009 07:36 PM
zumiez007
Dec 17, 2004 08:26 PM
2001LS-R
Dec 4, 2003 03:09 PM
mr_mbuna
Sep 14, 2002 06:53 PM
g35driver
Apr 20, 2002 06:14 AM
