temp gauge ?
Old Aug 28, 2002 | 08:20 AM
311's Avatar
311
Default temp gauge ?
my stock tempurature gauge does not work!! anyone know were the sensor is located on the engine for this?
btw, its a 91 integra w/b16
Old Aug 28, 2002 | 12:43 PM
311's Avatar
311
Default Re: temp gauge ? (311)
bump
Old Aug 28, 2002 | 02:06 PM
erniecars's Avatar
its a single pole connector under the distributor
Old Aug 28, 2002 | 02:12 PM
311's Avatar
311
Default Re: temp gauge ? (erniecars)
pole connector?? could you elaborate a little on what it looks like. you said it was under the distributor?
Old Aug 28, 2002 | 10:54 PM
erniecars's Avatar
single pole as in it has one wire. Its the only single wire connector on the head under the distributor. You cant miss it.
Old Apr 18, 2005 | 02:51 PM
DMax013's Avatar
Same problem with temp gauge not working..I converted to OBD1 and took out my rad. fan could these be causing this problem for any odd reason? Also at the time of starting my car I had no O2 sensor in. Could being in limp mode cause the temp gauge not to work?
Old Apr 19, 2005 | 03:45 AM
DMax013's Avatar
Default Re: temp gauge ? (DMax013)
bump
EF_SEDAN_LOVER
Nov 20, 2014 04:06 PM
BDaTurboTeg
Oct 26, 2013 12:55 PM
k.gren
12
Nov 1, 2011 09:18 AM
96_cvc_b16
Nov 21, 2009 04:37 PM
pburke23
Jul 2, 2004 09:55 AM
