Short block question...
Old Aug 25, 2002 | 10:45 AM
Passaudi1.8t's Avatar
New User
Default Short block question...
My 95 GSR is approaching 160k and I think that it may be due for a new shortblock. It's been blowing some blue smoke under hard acceleration, and I think my valve seals might be on their way out as well. I have the opportunity to get a 93 B16 shortblock for a good deal off a friend. I plan on using the GSR head, and I'm going to put new valve seals, titanium retainers, and stiffer valve springs while it is off the car. I also plan on still using my GSR tranny. What should I expect in terms of power? I know the B16 is 160/111, but I've also heard that the GSR head increases compression a little... what are the pros and cons to this set up? Thanks
Old Aug 25, 2002 | 11:59 AM
IN VTEC's Avatar
Default Re: Short block question... (vtecivicex)
Your block is fine (more than likely), and you'll absolutely regret getting the B16 engine. The loss of torque all across the powerband will have you pitching that engine quicker than $2.00 ***** gets on her knees.
All you need to do is freshen up the wear and tear items. Unless you crack or warp the block, it's perfectly reusable as long as the key components are intact.
Overhaul the engine and figure out what you need to replace. I'm in the process of doing this now. IM or e-mail me if you want to talk.
kaneboi
Aug 1, 2010 01:49 PM
j me4door
Mar 10, 2009 12:31 PM
toekneexD
Nov 17, 2006 07:59 PM
jdmjaser
Feb 7, 2006 02:52 PM
opiumdaze
Apr 18, 2005 07:17 PM
