retarding timing
Old Aug 23, 2002 | 01:52 PM
grocerygetter's Avatar
Default retarding timing
I have a NOS wet-kit on my 2001 LS integra. I'm using a MSD digital 6+. I'm going to use the 12volt trigger for the ignition box from the NOS switch(TB). How much timing do I need to pull out for a 50hp shot, 75hp shot, 100hp shot? You don't have to pull any for a 50hp shot at all, I think. I'm running one range colder NGKR plug, FYI.
Old Aug 24, 2002 | 06:10 PM
Default Re: retarding timing (grocerygetter)
I've posted other queswtions on this board before and no one answers them WTF? I guess I won't get any help here.
Old Aug 24, 2002 | 10:33 PM
CM-R's Avatar
If I were you I would get ngk BKR7E spark plugs. Then retard the timing for 75 shot to 12 degrees, 65 shot 14 degrees, 55 shot 16 degrees....hope that helps
Old Aug 25, 2002 | 04:49 PM
Default Re: retarding timing (CM-R)
That's a lot of timing pulled out! and you recommend 2 ranges colder on plugs. I had heard like 7-8 degrees out at 100 shot if you are using a wet kit and two heat ranges colder on plugs. Thanks for the info. Anyone doing anything different?
Old Aug 26, 2002 | 09:23 PM
b
XzIpK
May 13, 2007 07:16 PM
JDM H22
Jun 17, 2005 02:54 PM
SOHC_MShue
Nov 30, 2003 07:54 PM
Jared
Sep 11, 2003 01:11 PM
ExodusX187
Feb 24, 2003 06:00 AM
