Radiator problem
Old Aug 28, 2002 | 05:19 AM
metal-x's Avatar
Default Radiator problem
after installing a jrsc my car has been having some overheating issues
first off the fan won't com on and the car will overheat if I slide the heater to OFF and the put it all the way cold
the fan will only come on if I set the heater to OFF but slide it all the way HOT
I've replaced the rad as well and have a spoon rad cap but nothing works....
any ideas?
Old Aug 29, 2002 | 01:13 AM
integrx's Avatar
New User
Default Re: Radiator problem (metal-x)
try to bleed the radiator. i had overheating problems too. open the radiator cap and start the car. turn the heat on high at max(4) then let the car idle.
Old Aug 29, 2002 | 01:15 AM
MR. ARIZONA's Avatar
Default Re: Radiator problem (integrx)
FAL High Performance Radiator Fan
30% More Airflow!
Old Aug 29, 2002 | 05:19 AM
metal-x's Avatar
Default Re: Radiator problem (QUICKTEG)
my car has no AC so Im thinking of hooking up the second fan that should also help a bit,
pyrojeff
Oct 21, 2019 09:50 AM
FoRizzyy
Jun 5, 2012 06:53 PM
Mattyg2
Jun 1, 2004 02:46 PM
envious1320
Mar 9, 2003 04:50 PM
