HELP Check Engine Light Is On
Old Aug 27, 2002 | 01:47 PM
integraautox's Avatar
Default HELP Check Engine Light Is On
Ok I was driving my g/f's 2001 GSR home from school today when all of a sudden I noticed the check engine light came on. On her car she has an AEM CAI, JDM dc 4-1 header, carsound 2.5in high flow cat, and apexi n1 exhaust. I have had the mods on her car for a couple of weeks now with no problems So I dont think those are what did it or could I be wrong. Her car is a 2001 gsr with 18,000 miles on it. Are there any repairs supposed to be done at this time. i checked the oil and It was fine and the O2 sensors are all snug and in the right spot so I need some help here.
Old Aug 27, 2002 | 01:51 PM
ynotlim's Avatar
Default Re: HELP Check Engine Light Is On (integraautox)
I had a similar set up but on my 95 GSR but didnt have those problems... try reseting your ecu..
Old Aug 27, 2002 | 02:10 PM
uNF$@#!'s Avatar
Default Re: HELP Check Engine Light Is On (ynotlim)
uhm...
how about telling us what code is being thrown.
Old Aug 27, 2002 | 02:18 PM
Aaron M's Avatar
Default Re: HELP Check Engine Light Is On (Soup ****)
reset ECU
Old Aug 27, 2002 | 09:48 PM
bump
Old Aug 27, 2002 | 10:04 PM
ithrowpoop's Avatar
check the code. try c-speedracing.com for how to find out what code your car has.
Old Aug 28, 2002 | 07:24 AM
311's Avatar
311
Default Re: HELP Check Engine Light Is On (ithrowpoop)
the way you check the code, in case you dont know, is by pulling out a green rubber connector thing undernesth the far right side of the glove box. take a paper clip of a piece of wire and jump the harness. turn the key 2 clicks while watching the check engine light on the cluster. count how many flashes. a long flash counts as 10. then report back, and you may get some help.
98dxkoupe
Oct 2, 2018 04:32 PM
250r king
Apr 17, 2010 10:08 PM
Dodger2940
12
Dec 15, 2005 10:54 AM
wadafa
11
Oct 3, 2002 03:49 PM
TurboedGSR
Aug 21, 2002 11:37 AM
