help me with gearbox problem
Old Aug 24, 2002 | 09:39 PM
94thundergrey's Avatar
Default help me with gearbox problem
hi everyone:
my car develope a strange problem in last 2 days. It will not go in gear occasionally. it dose not grind, it simply won't go in any gears.
If the car is moving, I can rev the engine a little bit and force it into gear. if the car is stopped completely at a light, there is no way to shift, the only solution is to shut off the engine, put the car in gear, and restart the car in order to drive it.
this dose not happen all the time, maybe 5% of the shifts. It happen alot today. after I get the car going for a few shifts, the problem gose away, and shifts are normal again.
the warning before this shifting problem usually start with a strange cluth pedal feel, with some vibrations.
thanks for all your helps in advance.
Old Aug 24, 2002 | 09:41 PM
Default Re: help me with gearbox problem (94thundergrey)
oh, it's a 94 integra 2dr rs with 150k miles. on original cluth, and tranny fluid changed 6 months ago.
Old Aug 25, 2002 | 12:51 AM
ahead's Avatar
its most probably your clutch going out, but im not sure. check to see if your clutch fluid is full that may be the problem. goodluck
Old Aug 25, 2002 | 03:21 AM
vteg's Avatar
New User
Default Re: help me with gearbox problem (ahead)
Bleed your clutch, and save up for a new one. You can also try raising the pedal height, but this is a temporary patch for the real problem.
Old Aug 25, 2002 | 11:54 AM
Default Re: help me with gearbox problem (vteg)
thanks guys.
but I think a worn clutch will still let me shift, am I right.
I will check the clutch fluid and trany fluid later.
Old Aug 25, 2002 | 01:15 PM
vteg's Avatar
New User
It will let you shift. You have to take into account that the hydro mechanism may not be able to adjust for the amount it needs to push the fork forward to disengage the clutch. As you clutch wears this push becomes longer and the clutch disengages higher. Adjusting the pedal height higher gives you more fluid and leverage against the secondary when you push it. This will allow disengage your clutch.
Here is a pic stolen from the FI forum illustrating it:
This article has some good clutch info(beware it may be a little biased):
https://honda-tech.com/zerothread?id=215379
Old Aug 27, 2002 | 08:47 PM
hi vteg, thanks for your inputs.
I just bleed the cluth and change the tranny fluid today.
the tranny fluid looks more dirtier than the last time. the clutch fluid was very dirty as well.
however, these did not fix my probelm.
are we assuming that I need a new clutch because the car has 150k miles and on it's original clutch? I mean even if I have a worn clutch, I would still be able to change gear. and the problem I am having is unable to change gears. Also when the problem occurs, the transmission makes some noise(spinning noise like a loose belt coming from tranny case) and the clutch pedal vibrates if the clutch pedal is all the way down, if I lift it up a little, them the noise and vibration went away. And if i am already in gear, it is very hard to get to nutral as well. And the car drives fine most of the time.
Anyone out there experienced with a similar problem?
I do expect to replace the clutch soon, but this dose not sound like a worn clutch. IMO. If I know a new clutch will fix the problem, I will be happy.
Old Aug 27, 2002 | 09:04 PM
Paste's Avatar
Loved
How do you raise the pedal, my car has a similar problem and the clutch master cylinder was just replaced and its still a little crappy?
Old Aug 27, 2002 | 09:34 PM
Default Re: help me with gearbox problem (paste)
i don't think the clutch pedals are adjustable with hydrolic systems.
Old Aug 28, 2002 | 04:44 PM
vteg's Avatar
New User
They are. It took me a few minutes to figure it out though. Look under your dash, up the clutch pedal. There is a white plastic stub on the pedals stalk(I don't know what it is called). That stub rests against a bolt. There is a 14mm(I believe) nut that you loosen. Then you spin the assembly to move the bolt that it rests on up or down. Then retighten the nut. Then bleed your clutch afterwards and see if you like it.
This is a rough explanation, but if you look you will see what I am talking about.
Old Aug 28, 2002 | 09:19 PM
Paste's Avatar
Loved
How do you bleed your clutch, sorry dont have a helms.
EDIT- Like do you need any special things to do it?
[Modified by paste, 11:19 PM 8/28/2002]
Old Sep 11, 2002 | 04:33 PM
a new clutch is being put in to solve the problem.
it turns out 2 of the springs have been popped out. the clutch still have approx %30 life left.
I got a exady clutch from *** imorts for $265.
Old Sep 11, 2002 | 04:50 PM
lsteggy's Avatar
that is exactly what happend to me. i got a brand new clutch and all problem went away.
fkguitar
Feb 22, 2007 04:41 AM
rdssk8rcs1
Oct 17, 2006 11:38 AM
deejaycherub
Oct 27, 2004 03:19 PM
Outkasted24
Sep 22, 2004 06:30 PM
Jt240
Aug 23, 2002 05:11 PM
