Problems/Symptoms with Power Steering Failing...Help!
Old 11-14-2002, 10:59 AM
deep6's Avatar
Default Problems/Symptoms with Power Steering Failing...Help!
hey guys:
just wanted to see if anybody has had experience with their power steering failing or have fixed this problem in the past? my 94' GSR is making a loud metal ringing or rattling sound that seems to be coming from the power steering pump area when the car is idling at a stop. i've noticed for a while that fluid has been slowly leaking from the pump and splashing the bottom side of the hood directly above the P.S. pump...steering feels the same (no noticeable problems), only had to refill a little once to reach the top mark, and it's not coming from the new hose that i've had to replace--(the high pressure hose that leads to the top of the pump which came with a new O-Ring since the old hose was leaking from the sides of the metal fitting.) anyways, any help or information would be greatly appreciated...Help!
thank you.
Old 11-14-2002, 01:12 PM
dirtyazn's Avatar
Default Re: Problems/Symptoms with Power Steering Failing...Help! (deep6)
i know what your talkn about but its not the PS....its an idler pulley between the crack pulley and the A/C compressor, you might wanna take off the A/c belt and see if the noise is still there....about your PS leak, you could probably take it apart and fuc with it...but i dunno..its probably what i would do
[Modified by dirtyazn, 10:14 PM 11/14/2002]
ludelover86
04-10-2013 12:00 AM
professorman
02-24-2012 06:52 PM
Micha
Acura TL, RL & ZDX
35
03-27-2009 09:08 PM
ibme_uk
01-06-2005 08:23 AM
Quick Reply: Problems/Symptoms with Power Steering Failing...Help!
