force running cold
Old Nov 14, 2002 | 08:20 PM
crazyfiz's Avatar
Default force running cold
I heard that you can add a resistor to a line on your engine's temp sensor and it will trick the ecu to thinking that the engine is cold all the time. This would thus cause the ecu to send massive amounts of fuel to the engine and cause it to run better. I heard!!!! is this true and if so how do i accomplish this?
Old Nov 14, 2002 | 08:29 PM
piatl7il77's Avatar
Default Re: force running cold (crazyfiz)
In turn i think that the vtec wont kick in till the engine is above like 85 degrees. Plus why dont you just get bigger injectors, and get a hondata.
BABY NSX
Jun 10, 2013 05:16 PM
fleabag
Feb 26, 2010 04:28 PM
nyanyut
Dec 23, 2008 03:03 PM
SloEG
Oct 30, 2002 01:21 PM
SloEG
Oct 30, 2002 12:04 PM
