Quick valve adjustment question!
I am in the process of adjusting my valves, and i have the number on cylinder at TDC, the only thing that concerns me is that the rocker arms are loose. I kind of figured that they are supposed to be, but I just wanted to make sure I am doing everything alright!
Thanks
Thanks
at TDC, some will be loose, some wont... Just put your feeler gauge in on the lobes that are pointing away from the rocker arms. Adjust as necessary...
Make sure that you rotate the engine the proper direction to adjust the other ones... on Honda/Acura it is counter clockwise.
HTH
HTH
iam7head
Acura TL, RL & ZDX
Nov 20, 2008 10:11 AM
