check engine light #67
Old Nov 14, 2002 | 07:32 PM
GSRacer1's Avatar
Default check engine light #67
i am getting code 67 on my check engine light what could be the problem
Old Nov 14, 2002 | 08:42 PM
piatl7il77's Avatar
Default Re: check engine light #67 (GSRacer1)
Here is a list of all the codes... Do a search next time.
http://www.team-integra.net/sections...p?ArticleID=34
Old Nov 14, 2002 | 08:44 PM
:jdmshmaydm:'s Avatar
Check Engine Light #67 = Low Catalyic Converter Efficiency
Did you hollow out your cat? Got a test pipe? Basically the 02 sensor's sensing something different than normal on your cat. Check it out.
Old Nov 14, 2002 | 10:00 PM
Malice's Avatar
New User
Default Re: check engine light #67 (Gatecrasher18AF)
gotta love obdII
Old Nov 15, 2002 | 09:56 AM
GSRacer1's Avatar
no i did not get a test pipe or hollow out my cat what else could it be
Old Nov 15, 2002 | 10:45 AM
Fez's Avatar
Fez
Sounds like you need to replace your cat.
Old Nov 15, 2002 | 11:01 AM
B00ST2nR's Avatar
Default Re: check engine light #67 (GSRjunky)
Your car should run fine even with the CEL on. You can always reset your ECU to get rid of it.
If i were you, I'd just get a new cat and then reset it.
Old Nov 15, 2002 | 12:38 PM
Dirty GS-R's Avatar
New User
Default Re: check engine light #67 (Skunk2nR)
integraftw98
Oct 16, 2006 07:06 PM
fastitr01
Jun 6, 2004 06:17 AM
B18CR-X
Oct 6, 2003 11:34 AM
ryu12341
Oct 12, 2002 09:16 PM
vtec_racer_2kgsr
Sep 20, 2002 05:09 PM
