short shifter?
Old Nov 17, 2002 | 11:14 AM
n0 iNTegRiTY's Avatar
Default short shifter?
would you guys reccommend a short shifter for my teg? or would i regret it? cuz i need ideas for $50 and under, and im considering that among other things such as a shift ****.
Old Nov 17, 2002 | 02:22 PM
Default Re: short shifter? (RAF LTD. 2)
cmon... anybody?
Old Nov 17, 2002 | 02:31 PM
SiRex91's Avatar
Don't buy one of those cheapass short shifters. All it will do is make you grind up your syncros.
Old Nov 17, 2002 | 03:16 PM
tegasaurus's Avatar
Default Re: short shifter? (SiRex91)
The reason you grind your gears is because you aren't use to the shorter shift. Which means that you'll have to push the clutch in faster to make up for the faster shift.
I have a "cheap ebay brand" shifter and love every moment of it. I also have an ACT XTSS so the shifts are short and snappy.
It will take some getting use to, you'll miss 2nd gear a couple of times and possibly go from 2nd to 5th until you get use to the shorter distance. Put it in, on the first test run, don't rip through the gears, just learn your shifter. I love mine
Old Nov 17, 2002 | 03:32 PM
Regular Series's Avatar
I'd reconsider, especially on your budget. I have a $60 Ractive shifter that has never fit quite right despite many hours under the car.
I'd say get some shifter bushings. They make a noticeable difference in the feel of your shifter, and fit right the first time. After you get them, you probably won't want to bother with a short shifter.
[Modified by risingson77, 7:32 PM 11/17/2002]
Old Nov 17, 2002 | 03:56 PM
Fuuma0083's Avatar
Default Re: short shifter? (risingson77)
Old Nov 17, 2002 | 06:03 PM
thanks for the suggestions
Old Nov 17, 2002 | 06:27 PM
acatak's Avatar
DC Sports Short Shifter
Old Nov 17, 2002 | 06:33 PM
roydogg's Avatar
Default Re: short shifter? (acatak)
no problems here
Old Nov 17, 2002 | 06:57 PM
neo1z's Avatar
Default Re: short shifter? (roydogg)
ah Skunk2 all the way.
Old Nov 17, 2002 | 07:26 PM
Dee's Avatar
Dee
Default Re: short shifter? (neo1z)
Get the shifter bushings!!
I have an extra C's for sale ($150) if you ever decide to spend a little more money.
Old Nov 17, 2002 | 07:55 PM
Aaron M's Avatar
Default Re: short shifter? (Dee)
ill be replacing my B&M with a skunk2 very soon....
so i say Skunk2
Old Nov 17, 2002 | 08:08 PM
95 integra's Avatar
Default Re: short shifter? (SilverB18C1)
I say DC
[Modified by 95 integra, 11:09 PM 11/17/2002]
Old Nov 18, 2002 | 01:23 AM
AccrdATK's Avatar
New User
Default Re: short shifter? (95 integra)
id go with Cs if i ever got a short shifter... also wasnt there a post in the type r forum.. some guy broke his DC short shifter... it looked like it broke off pretty smooth too..
Old Nov 18, 2002 | 05:48 AM
IntEGNYC's Avatar
no problems here
Same here!
Old Nov 18, 2002 | 06:17 AM
Ricky Rojales's Avatar
In this order:
<FONT COLOR="green">BEST</FONT>
C's
B&M Pro Edge
SKUNK2
<FONT COLOR="blue">GOOD</FONT>
DC Sports are suspect of breaking off at the threads. <FONT COLOR="red">Unacceptable</FONT>
[Modified by P, 10:19 AM 11/18/2002]
Old Nov 18, 2002 | 06:23 AM
Full Race EG's Avatar
Default Re: short shifter? (P)
Skunk2
Old Nov 18, 2002 | 09:02 AM
SOHC_MShue's Avatar
Default Re: short shifter? (IntegraLStuner)
would you guys suggest getting shift bushings for a short shifter? or just for stock shifter?
Old Nov 18, 2002 | 09:43 AM
allmotorls95's Avatar
Default Re: short shifter? (98exShifter)
just chop off the shifter and get it threaded to 10mm ...spend the 50 on sum weed or sumthin
or go with a skunk...
[Modified by allmotorls95, 6:44 PM 11/18/2002]
uses0ap
Mar 8, 2010 10:41 AM
C1CRX
Sep 5, 2006 09:22 PM
ketchup
17
Aug 26, 2004 08:42 AM
m3dia_lab
48
Aug 9, 2003 12:54 PM
Modifiyem
Jul 31, 2003 06:30 AM
