Adjusting Valve Lash
Old Mar 24, 2003 | 04:21 PM
Evil EG's Avatar
Default Adjusting Valve Lash
Ive seen it here before but couldn't find the link.....How do you make your own tool for the GSR dont you like bend a wrench or somthing? Thanks I need to adjust this and am too cheap to get the right tool.
Old Mar 24, 2003 | 09:10 PM
Evil EG's Avatar
Default Re: Adjusting Valve Lash (BVM)
no one has done this befor....
Old Mar 24, 2003 | 09:24 PM
thx247's Avatar
5 hours is hardly long enough.
You can either use a blow torch and make your own tool out of a 10mm socket (I did that one)
Or there is a tool you can buy, search honda acura net for it, it was posted maybe a month ago.
Either way, get a tool of some kind or its a BITCH.
Old Mar 24, 2003 | 09:26 PM
Aaron M's Avatar
Default Re: Adjusting Valve Lash (thx247)
get the snap-on
Old Mar 24, 2003 | 11:04 PM
intekragsr's Avatar
Default Re: Adjusting Valve Lash (SilverB18C1)
This is what I did.
Old Mar 24, 2003 | 11:10 PM
400whp's Avatar
Default Re: Adjusting Valve Lash (intekragsr)
Hmmm...That is a really good idea! What did you use to bend the wrench? blow torch on low?
Old Mar 24, 2003 | 11:19 PM
intekragsr's Avatar
Default Re: Adjusting Valve Lash (TonyT)
I just brought it to my exahust shop and had them do it for me. Just make sure the closed end of the wrench is bent short enough to fit inside the small area of our engines.
Old Mar 25, 2003 | 04:38 AM
Evil EG's Avatar
thank you that is what i was looking for.
Old Mar 25, 2003 | 07:03 AM
Nameless RB26's Avatar
I screwed up 3 wrenches because I bent them wrong.
If you're going to bend one, make sure you do it VERY close to the end because it won't fit otherwise.
Old Mar 25, 2003 | 07:17 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Adjusting Valve Lash (Nameless)
The bent wrench method is extremely difficult to use. A valve adjusting tool is MUCH easier. Too bad Harbor Freight doesn't sell their 4-piece set for $25 anymore. Good thing I bought mine when I did.
Gomdohree
Jun 2, 2008 05:53 PM
Sketch_hs
Feb 9, 2006 07:38 AM
JETSPD1477
Oct 6, 2005 09:20 PM
KOALA YUMMIES
Jul 20, 2004 06:23 AM
py1188
Apr 30, 2002 03:23 PM
