Compression Test #'s
Here are some numbers, can yo tell me if this thing is healthy? I'm a little worried about cylinder #2! Here are the #'s 240......221......235......236 They dont seem to bad to me but i just wanna run it by you guys just incase. Thnx
yeah that is a bit on the high side, maybe carbon buildup? you should be ok though cuz they are within 20psi of each other.
my gsr came out 210 212 220 212
[Modified by tilt, 7:28 AM 3/26/2003]
B18B1's should produce roughly 200 psi of compression per cylinder. (Although yours is a 96, which may show slightly lower numbers.) Anything above 130 psi is fine, provided that the variation between cylinders is not excessive.
Your cyl. reading 150psi should worry you (50+ psi diff. from rest.)
Mike
stock GSR? if it is, nothing to worry about. My recent compression test looked like this:
210...210...206...150
Mike
Mike
something in my car is hosed heh also for a stock GSR (well, it has a CAI that's it)
You can do them yourself. Go to Kragen and pick up a compression test gauge for about $30.
EDIT: In fact, it's so easy that I tested 2 cars at our last Nothern California Integra Meet. Did it right in the parking lot. Probably took about 5 minutes per car.
[Modified by neouser, 7:13 PM 3/26/2003]
is there a web page that shows how to do a compression test?
