eibach pro kit drop??
Old Mar 26, 2003 | 10:59 PM
natrl's Avatar
Default eibach pro kit drop??
i just put in my eibach pro kit springs ...the front ( with a 3 finger gap) sits higher than the rear (with a 2 finger gap), i know the front will break in a little so the front and rear will look level to eachother...so, my question is, will the rear springs break also break in which will give me an uneven look???
Old Mar 26, 2003 | 11:05 PM
B U N M A N G O's Avatar
Default Re: eibach pro kit drop?? (natrl)
do you have a two door or a four door? on four doors, which sit lower, the fronts or the backs? just wondering.
Old Mar 26, 2003 | 11:20 PM
natrl's Avatar
Default Re: eibach pro kit drop?? (bunmango)
i have a two door
Old Mar 26, 2003 | 11:34 PM
xteg95's Avatar
i think all the eibach springs have a lower drop in the rear...i know my sportlines do. not 100% sure about the pro-kits.
Old Mar 27, 2003 | 06:23 AM
Just2Fast's Avatar
Default Re: eibach pro kit drop?? (xintegra01)
Thats the way the prokit looks. I have them on my car and the back looks lower than the front but the car is pretty much even.
Old Mar 27, 2003 | 07:16 AM
tilt's Avatar
Default Re: eibach pro kit drop?? (Just2Fast)
yep the rear will be lower. if you take everything out from the back it will be close to even but it will still sit lower.
Old Mar 27, 2003 | 07:26 AM
p nut's Avatar
Default Re: eibach pro kit drop?? (tilt)
I thought this had been discussed a million times before and we finally came up with the fact that since the front fenders are bigger than the rear ones, the front will "look" higher. I have the prokits, too and it took about 1.5-2 weeks for it to settle. I am pleased with the drop.
Old Mar 27, 2003 | 10:05 AM
natrl's Avatar
Default Re: eibach pro kit drop?? (con)
kOO....thanks everyone
Old Mar 27, 2003 | 12:28 PM
spoonfed95's Avatar
I hate the way spring only lowering kits look. I would save up and get some ground controls.
Old Mar 27, 2003 | 01:49 PM
yangrou8's Avatar
con, did u wait till after your springs to settle before you got an alignment or did u get the alignment right away? im gonna be puttin these on when the weather clears up..
Old Mar 27, 2003 | 02:29 PM
p nut's Avatar
Default Re: eibach pro kit drop?? (yangrou8)
I waited for a couple of weeks to let the springs settle, which was what I was advised to do by the alignment shop. So unless you have serious alignment issues right now, I'd wait.
jagumbel
Feb 18, 2011 02:13 PM
onnoff7
Suspension & Brakes
Apr 18, 2006 11:48 PM
SpankyG
Sep 30, 2005 11:00 AM
hondaracin24
Sep 29, 2004 10:05 AM
spdster
Sep 11, 2002 11:16 PM
