engine mounts are starting to go
Old Mar 28, 2003 | 03:03 PM
mattL's Avatar
Default engine mounts are starting to go
i know my front mount by the ac compresor is torn but i'm not sure if any others are bad, i can feel a lot of flex in the motor and i'm going through axles every 6 months, would doing some ES urethane inserts be a fix, or is it better to replace the mounts? wheres the best place to buy them? thanks
Old Mar 28, 2003 | 04:13 PM
964dgsr's Avatar
Default Re: engine mounts are starting to go (mattL)
bump,
Cause I want to know too.
Old Mar 28, 2003 | 05:48 PM
DSayavan's Avatar
I've got some brand new Energy Suspension mount inserts for sale if you're interested.
[Modified by DSayavan, 2:49 AM 3/29/2003]
Old Mar 28, 2003 | 06:18 PM
mattL's Avatar
Default Re: engine mounts are starting to go (DSayavan)
how much?
Old Mar 28, 2003 | 06:31 PM
94TealGSR's Avatar
Automotive Engineering has them for pretty cheap. They're on US19.
Old Mar 28, 2003 | 07:27 PM
romeo619romeo's Avatar
Default Re: engine mounts are starting to go (94TealGSR)
instead of that.. just fill in the mounts that are torn.. with rubber silicone... it would basicly turn into solid mounts.. cheap too
Old Mar 29, 2003 | 01:35 PM
mattL's Avatar
Default Re: engine mounts are starting to go (romeo619romeo)
so you think that if i do the inserts i can avoid getting new mounts or do both?
Old Mar 29, 2003 | 01:54 PM
94TealGSR's Avatar
If your monts are gone already, the inserts will not help.
If your mounts are not yet gone, then get the inserts ASAP.
Old Mar 29, 2003 | 01:57 PM
Rory Breaker's Avatar
You can use ES mounts with torn/old motor mounts. It still effectively creates a solid mount.
Theyre cheap as well....maybe $35?
clem kevin
May 1, 2008 06:57 PM
white_db8
May 26, 2007 09:34 AM
integrawow
Suspension & Brakes
Nov 10, 2006 09:48 PM
00000xxx
Oct 15, 2004 10:50 PM
mingchi69
Feb 20, 2004 08:08 PM
