Skunk2 Cam setup problem!!!!!
Old Mar 26, 2003 | 04:23 PM
Havokgsr
Guest
Posts: n/a
Default Skunk2 Cam setup problem!!!!!
hey hows it going... i posted some stuff about my car install with the skink2 cams and i've been having some problems with it so far.. i feel as if my car is slower due to the cams... i bought the cams used with cam gears.... i got them from a skunk2 distributor out here in cali.... the cams were already dyno tuned to another gsr... with intake header exhuast IM ecu chip.... and all i have is intake headers... ok to the point im trying to make ... the car feels the same around 1k-4k but when it reaches about 4300-5500 the car freaken lags like hell there..... then after that the car rips like a bat out of hell, but then when i shift into second it goes into that 4300-5500 for a quick sec and still boggs on out.. what do you think is causing this... IS IT THE DUAL VTEC THAT GSRS HAVE? IS IT THE EXHHUAST? OR IS IT THE FACT THAT THEY ARE ADVANCED AND RETARDED CAMS FOR ANOTHER CAR NOT MINE??? or is it the fact that my cars a 95 obd1 and not obd2????
please send soem info on this!!!! thanks!!!!
Old Mar 26, 2003 | 04:25 PM
B00ST2nR's Avatar
Default Re: Skunk2 Cam setup problem!!!!! (Havokgsr)
Like I said in the PM, its because you need DYNO TUNING. They can fix that DIP in the mid-range, and set your car to the maximum potential. Don't worry... nothing is wrong with your car or setup. Just get it tuned and it will be all gravy.
Teamdiesel
16
Sep 3, 2017 08:34 PM
94draglude
25
Nov 13, 2007 12:41 PM
neophyte210
38
Oct 3, 2005 10:04 AM
EARLdaSQUIRREL
May 1, 2003 11:24 AM
