compression test
Old Mar 29, 2003 | 09:56 AM
CNSK's Avatar
Default compression test
what fuse to i need to take out before i do my compression test? under my steering wheel or underneath the hood?
do i take out the fuse, remove spark plugs, plug up the compression tester, floor the gas pedal and crank the ignition on for 5 times? correct me if im wrong please.
also, when im going to test it, do i remove the spark plugs and test one at a time, or remove all of the spark plug at once and then test it?
i try going to c-speed racing.com i think, and seems like there site is down. i know they give a breif description in it cause last week i was in there site and now i cant seem to get in.
Old Mar 29, 2003 | 10:26 AM
CNSK's Avatar
Default Re: compression test (DrMartin)
anyone??
Old Mar 29, 2003 | 10:44 AM
geminis2k's Avatar
Remove your 15A fuse under the hood. I usually do 1 spark plug and 1 wire at a time, since the car won't start with the fuse out anyway. Get in the car, go WOT, crank it 5-7 times, rinse, wash, repeat.
This has been covered several times on the board, please do a search next time
Old Mar 29, 2003 | 10:46 AM
ragejed's Avatar
Default Re: compression test (geminiGSR)
I remove all the spark plugs when I did mine.
Old Mar 29, 2003 | 11:05 AM
TerribleOne's Avatar
Default Re: compression test (ragejed)
yeah its best to remove all the spark plugs, turn it over till the meter stops moving (6-7 times) and WOT is wide open throttle just so you know, push the gas pedal all the way down, I got 225 across the board on my b18c1 w/ 53000 miles I was very pleased
Old Mar 29, 2003 | 12:45 PM
CNSK's Avatar
Default Re: compression test (TerribleOne)
thanks for all your help
94DCTeg
May 21, 2025 09:22 AM
B18CivicHatch
Aug 24, 2007 12:11 AM
Traction
Apr 6, 2004 06:11 PM
monkijunki
Dec 2, 2003 03:16 PM
JunIntegra
May 22, 2003 04:12 AM
