Broken header stud, is it bad?
Old May 29, 2003 | 03:34 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Broken header stud, is it bad?
I noticed a small amount of black soot on the head right around the broken header stud, which has been broken for at least a year now (last stud towards the distributor). Is this bad? I know I need to replace the stud but I will have to find the time to drain and remove the radiator and all that stuff so I can get room to drill it out.
Old May 29, 2003 | 03:42 PM
tilt's Avatar
Default Re: Broken header stud, is it bad? (PatrickGSR94)
Worst case scenario I've heard you can burn valves, but I seriously doubt you will since it's not leaking that bad. You can however get carbon monoxide poisoning if you turn off recirculate on the a/c and the exhaust fumes get inside... but again, a fairly low risk.
Ive been running with a broken stud (left bottom as well) for a few months now and havent noticed any leaking as far as I can tell. I will replace it eventually though.
Old May 29, 2003 | 05:23 PM
P1mpSlap's Avatar
WTF
Must be the OBD1 GSR motors or something. My friend has the same problem. Same area. He rode around with that thing for a while. He just drilled it out and it took him forever. He tried about every bolt extractor on the market. LOL
Old May 30, 2003 | 12:42 AM
sleepinonacreeper's Avatar
Default Re: (P1mpSlap)
weld weld weld, build the stud out of the head by stacking tacks then tack a nut and twist it out, works great. gotta take off manifold or you'll make a mess.
Old May 30, 2003 | 05:54 AM
THE94GSR's Avatar
Default Re:
this seems like a common problem in gsr i had it happend to me when i was changing my headers i took it to a shop and had them re-thead the hole
JDM_95_LS
Feb 2, 2007 07:14 PM
Jdmglenn
Jan 31, 2005 09:50 AM
Project_ED8
Mar 10, 2004 11:36 AM
ophdehEEzY
Apr 29, 2003 03:46 AM
ophdehEEzY
Apr 27, 2003 02:32 AM
