Indiglos???
Old Jun 2, 2003 | 09:58 PM
StockTeg's Avatar
Default Indiglos???
Ok, as a last resort, I have decided to get indiglos gauges for my car because the gauge cluster doesn't light up anymore. I have replaced the bulbs and fuse but no luck. Im guessing it has to do with the wiring.
Some questions,
Where are the indiglos connected?
Do they need the factory light bulbs to help them glow?
Thanks.
Old Jun 2, 2003 | 10:03 PM
sPaRk'iT's Avatar
Default Re: Indiglos??? (StockTeg)
black wire connect to ground, anywhere that can be grounded, and red wire to the instrument, just connect the red wire to the fuse into the instrument fuses box. then it should work fine. And no you dont need any light bulb to make it light up. Hope that helps!
Old Jun 2, 2003 | 10:53 PM
xteg95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StockTeg &raquo;</TD></TR><TR><TD CLASS="quote">Ok, as a last resort, I have decided to get indiglos gauges for my car because the gauge cluster doesn't light up anymore. I have replaced the bulbs and fuse but no luck. Im guessing it has to do with the wiring.
Weird same thing happened w/my bros car, we ended up putting guages in there like youre doin. Does your center console lights work either? We never bothered to figure out what was wrong, if you ever figure out what was wrong shoot me a PM
Old Jun 3, 2003 | 05:39 AM
94ls's Avatar
thats very weird man... sorry to hear thats giving you trouble but at least you have an alternative. let me ask you this... have you ever swapped out the bulbs behind the guages before? Meaning have you ever put different colored bulbs such as amber or red behind there? im just curious.
Old Jun 3, 2003 | 05:50 AM
StyleTEG's Avatar
Default Re: Indiglos??? (94ls)
The needles themselves are backlit by the bulbs, so those won't light up if they are not working now. But it still should be visible from all the light on the gauges themselves.
Old Jun 3, 2003 | 08:18 AM
integrase96's Avatar
ahhh
Old Jun 3, 2003 | 08:21 AM
P1mpSlap's Avatar
say no to rice
Brett's Avatar
Default Re: (integrase96)
odometer won't light up
Old Jun 3, 2003 | 09:04 AM
StyleTEG's Avatar
Default Re: (P1mpSlap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">say no to rice</TD></TR></TABLE>
say "its not your car, let him do what he wants"
Old Jun 3, 2003 | 09:14 AM
Pinkertinkle's Avatar
Don't get regular indiglo's. The circles pf blue/green-ness is going to kill your night vission and make driving dangerous. Get the reverse indiglo's that don't light up too much.
Old Jun 3, 2003 | 09:36 AM
97CivicLS's Avatar
i have the reverse indiglos and i love them. they look good. you can hook them up the dimmer switch. ground, and then on the constant power i think. there are 3 wires. unconstant power being the last one. try it on both. i cant remeber which one i used.
Old Jun 3, 2003 | 10:10 AM
integrx's Avatar
New User
you should double check your fuses
Old Jun 3, 2003 | 11:06 AM
Brett's Avatar
Default Re: Indiglos??? (integrx)
get regular ones and don't get ac autotechnic, mine have spots all over that don't light up.
Old Jun 3, 2003 | 12:01 PM
95 Gizzer
Guest
Posts: n/a
Default Re: Indiglos??? (Brett)
I got reverse indiglos on ebay, and they looked really good, but they made it so my needles wouldnt be able to move, so I had to take them off
Old Jun 3, 2003 | 12:13 PM
LSvtec03's Avatar
Default Re: Indiglos??? (95 Gizzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 Gizzer &raquo;</TD></TR><TR><TD CLASS="quote">they made it so my needles wouldnt be able to move, so I had to take them off</TD></TR></TABLE>
i know someone whos did the same thing. double-sided tape makes it all better
Old Jun 3, 2003 | 12:21 PM
Kazz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 Gizzer &raquo;</TD></TR><TR><TD CLASS="quote">I got reverse indiglos on ebay, and they looked really good, but they made it so my needles wouldnt be able to move, so I had to take them off</TD></TR></TABLE>
had same problem just use glue stick or something
Old Jun 3, 2003 | 12:33 PM
95 Gizzer
Guest
Posts: n/a
Default Re: Indiglos??? (JuuKe_EM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JuuKe_EM &raquo;</TD></TR><TR><TD CLASS="quote">
had same problem just use glue stick or something</TD></TR></TABLE>
I used superglue, but they still stuck, so I had to take them off, and they left nasty residue all over that wouldnt come off, so I had to buy a new cluster
Old Jun 3, 2003 | 02:28 PM
IntEGNYC's Avatar
use the double sided tape from 3M to keep the gauges stationary.
I noticed that the lighting in the center of my dash (light between the two main gauges) were darker than the rest of the dashboard. I'll probably swap out the bulbs eventually.
I dont recommend colored bulbs or LED's. colored bulbs are darker no matter what color they are and LED's are directional so they will shine unevenly behind the gauges as well.
Good Luck to ya
Old Jun 3, 2003 | 02:39 PM
Havokmkr's Avatar
Default Re: Indiglos??? (IntEGNYC)
Whatever you do, do not ground out the wire to the metal piece under the guage cluster. If you have to connect a piece of wire to make it longer then do it. Ground it away from the cluster or you will fry it.
Old Jun 3, 2003 | 03:06 PM
StockTeg's Avatar
Default Re: Indiglos??? (xintegra01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xintegra01 &raquo;</TD></TR><TR><TD CLASS="quote">
Weird same thing happened w/my bros car, we ended up putting guages in there like youre doin. Does your center console lights work either? We never bothered to figure out what was wrong, if you ever figure out what was wrong shoot me a PM </TD></TR></TABLE>
Half of my center console works. And sometimes it doesn't. I just give it a little knock and some of the lights come back. It sucks.
I'll probably go buy some indiglos soon.
Well thanks to everyone that helped out. I appreciated it.
mcgee*
Mar 7, 2007 02:18 PM
Rex89
Oct 12, 2006 04:18 PM
g2xsi
Dec 29, 2005 07:32 AM
dungsta
13
May 22, 2005 09:28 PM
hypnotic
Sep 30, 2003 08:32 PM
