cai installation
Old Jun 1, 2003 | 11:57 PM
integraL's Avatar
Default cai installation
how did you guys with AEM CAIs install your CAI? did you take off the wheel well from the fender? did you take off yoru front bumper?
Old Jun 2, 2003 | 12:00 AM
B00ST2nR's Avatar
Default Re: cai installation (2001gsRguy)
you can just turn the steering wheel all the way and you won't have to take off the wheel or the bumper.
Old Jun 2, 2003 | 09:44 PM
integraL's Avatar
Default Re: cai installation (Skunk2nR)
anyone else know?
Old Jun 2, 2003 | 09:46 PM
thaiphob's Avatar
Nikon!!!
same thing skunk2nr said, that the easiest way.
Old Jun 2, 2003 | 09:50 PM
integraL's Avatar
Default Re: cai installation (thaiphob)
thai, how would you get the resonator off? and would you jack up the car?
Old Jun 2, 2003 | 09:53 PM
B U N M A N G O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaiphob &raquo;</TD></TR><TR><TD CLASS="quote">same thing skunk2nr said, that the easiest way.</TD></TR></TABLE>
wow skunk2nr giving installation advice? I could've sworn it was just yesterday that he posted his own "how do I install my AEM intake?" thread
King_j's Avatar
http://www.team-integra.net ----&gt; articles
Old Jun 2, 2003 | 10:27 PM
integraL's Avatar
Default Re: cai installation (King_j)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King_j &raquo;</TD></TR><TR><TD CLASS="quote">http://www.team-integra.net ----&gt; articles</TD></TR></TABLE>
i read that article, it tells me to take off the bumper, do i hav eto jack up the car? how woudl it ake out the resonator if i take off the wheel well?
Old Jun 3, 2003 | 12:00 AM
B18CYAAA's Avatar
Remove the entire stock intake. Then bolt intake piping to tb with the aem coupler. Then jack up the car, go underneath the car and place the filter on the end of the piping. You shouldn't have to take off any bumpers or fenders. However, you may have to take off the fender liner and then reinstall it.
Old Jun 3, 2003 | 12:24 AM
zer0zer0 TypeR's Avatar
remove the rim, it'll make work alot easier. the resonator is held up by 2 or 3 bolts i believe i can't remeber. It's pretty simple once you get started
Old Jun 3, 2003 | 12:26 AM
B2FiNiTY's Avatar
Default Re: cai installation (zer0zer0 TypeR)
I never needed to remove the rim but it does make it a lot easier. A stock jack is also enough to lift the car high enough.
Old Jun 3, 2003 | 06:31 AM
J337_UNIT's Avatar
Default Re: cai installation (B2FiNiTY)
this is not a mod that takes skill. just sit there and figure it out its not that hard. u gotta remove (unbolt) some of the fender well and fold it out to get to the big white box i call it (resonator) and there should be like ~3 bolts that holds that box in place. Take them out and if the box can jiggle and move around but feels like it wont slide out then you probly missed a bolt and try to locate it. i remember there was one that was hidden pretty well. Once you remove that one the box should almost fall out and then you have to manuever it out of the fender well.
Old Jun 3, 2003 | 07:45 AM
Hairy Gorilla's Avatar
Default Re: cai installation (J337_UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT &raquo;</TD></TR><TR><TD CLASS="quote">this is not a mod that takes skill. just sit there and figure it out its not that hard. u gotta remove (unbolt) some of the fender well and fold it out to get to the big white box i call it (resonator) and there should be like ~3 bolts that holds that box in place. Take them out and if the box can jiggle and move around but feels like it wont slide out then you probly missed a bolt and try to locate it. i remember there was one that was hidden pretty well. Once you remove that one the box should almost fall out and then you have to manuever it out of the fender well. </TD></TR></TABLE>
He said it pretty well. I just used the stock scissor jack and lifted up the front. Removed the front right wheel. I then pulled the fender lining out of the way. It is pretty straightforward from there on. Basically pull out everything connected to the stock intake. Probably 10 bolts total. Just rip out everything and the CAI is very easy to install from there. A lot less ****.
Hope this helps
beebeecivic
16
Oct 11, 2006 10:40 PM
import810
Nov 7, 2005 02:42 PM
Honda97
Feb 14, 2005 06:14 PM
RacerSi
Dec 30, 2003 12:57 PM
DK4200
May 18, 2003 11:38 AM
