ABS light is on?!?
Old Jun 2, 2003 | 06:05 PM
Hybrid CRX's Avatar
New User
Default ABS light is on?!?
i got a 95 LS and the ABS light comes on somtimes....almost all the time....what could be the problem? I've been told low brake fluid?
Old Jun 2, 2003 | 06:38 PM
NeoGSR's Avatar
Default Re: ABS light is on?!? (Hybrid CRX)
low brake fluid....worn pads or a bad ABS sensor....i think
Old Jun 2, 2003 | 06:58 PM
GS-R Jay's Avatar
Hopefully it's not the sensor...mine is bad and it is costing me $350 to repair it.
You can check the ABS code yourself...e-mail or PM me and I can send you the link on how to do it.
Old Jun 2, 2003 | 07:02 PM
ponytd's Avatar
if the light does not go off after you start the car it could be several different thingss uch as a bad relay, a blown fuse or a faulty abs pump, to name a few. it would be best to go to a mechanic and get it checked out and hopefully it isn't serious.
Old Jun 2, 2003 | 07:31 PM
Hybrid CRX's Avatar
New User
Default Re: ABS light is on?!? (ponytd)
it comes on every now and then when im driving, i feel grinding in my peddles everytime im about to just stop.....maybe pads.....fluid is good
Old Jun 2, 2003 | 08:03 PM
vain's Avatar
sign up on http://team-integra.net
then go to ...
http://www.team-integra.net/se...D=493
Old Jun 2, 2003 | 09:15 PM
Hate's Avatar
Default Re: (vain)
same problem with mine. 94-97's ABS pumps were ****. they upgraded in 98. its prollt just an O-ring that costs 1.25 in your accumulator. dont quote me on this. but worth a shot. it fixed my problem and the damn acura dealership said i needed a whole new ABS pump. which would cost a lot.
Old Jun 3, 2003 | 03:42 AM
HiRevn's Avatar
Default Re: (Hate)
When mine came on, I had an obvious leak coming from somewhere on the bottom of the ABS pump. They ended up replacing the entire ABS pump. Hopefully that's not the problem on yours coz that thing is expensive.
bonstokLS
Mar 30, 2014 10:51 PM
newhondaowner29
Jan 11, 2006 08:11 PM
redINTEGRAdriver
Jan 31, 2005 12:01 PM
f22suzuka
Apr 21, 2004 10:15 AM
CNSK
Apr 12, 2003 11:13 PM
