checkengine light
Old Jun 3, 2003 | 06:48 AM
rota426's Avatar
Default checkengine light
had a small oil leak, filled it up and oil is fine now but my check engine light is still on....anyone have any suggestions?
tia
Nate
Old Jun 3, 2003 | 08:11 AM
integrase96's Avatar
did u reset the light after u added oil, or did u check the code to see what it was????
Old Jun 3, 2003 | 09:34 AM
DOHCon15s's Avatar
Default Re: (integrase96)
hey that happened to my brothers civic and he did the same thing that you did but when your oil pressure decreases like when you pull the e-brake and turn or turn really sharp really fast it will go back on. So go get it reset adn change your oil and it will be straight. At least you know it works though cuz most tegs dont.
Old Jun 3, 2003 | 09:55 AM
neo1z's Avatar
Default Re: (DOHCon15s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCon15s &raquo;</TD></TR><TR><TD CLASS="quote">hey that happened to my brothers civic and he did the same thing that you did but when your oil pressure decreases like when you pull the e-brake and turn or turn really sharp really fast it will go back on. So go get it reset adn change your oil and it will be straight. At least you know it works though cuz most tegs dont.</TD></TR></TABLE>
Most tegs dont what? Work? Okay.
To reset the ecu, just pull the fuse, let it sit for a couple mins, and put it back in and let it idle for a bit.
slayerfromhell212
Jan 1, 2007 02:26 AM
motormike40
Aug 21, 2006 06:02 PM
Foxcow
10
Dec 16, 2004 08:56 PM
lemongreenhatch
10
Aug 15, 2004 06:47 AM
SixPAK
Aug 17, 2003 10:47 PM
